Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Audiophile Ethernet Switch
Old 25th February 2020, 07:03 PM   #451
ferret is offline ferret  South Africa
ferret's Avatar
Cogitech, dang your idea of a Faraday cage might not be too unobtanium!
But to be honest, the biggest problem on the power feed (at least where I am) is the horrible amount of phase shift. The electrical engineers (@ the varsity where I work) have done measurements in the past and have reported 30% and more depending on the time of day (or night,) and the season (lots more worse in winter.) I'm not certain how much that will affect our Hi-fi equipment
Ferret. - Gaya rules
Old 25th February 2020, 07:05 PM   #452
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by cogitech View Post
Not if that "noisy SPMS" plugged into the same circuit as the audio system is the actual "problem". Fiber wouldn't make a lick of difference.
Use batteries then, Bill likes batteries
Old 25th February 2020, 10:34 PM   #453
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Originally Posted by ferret View Post
Indeed, but I have tried a TOSLINK cable and a coaxial cable from the same source into my preamp (AudioLab 8200CDQ) at the same time, played a quality CD (Jazz At The Pawnshop) for some friends (some AudioPhools and some not) and they all preferred the coaxial (of course I never told them which one I was using) and this was setup before anyone arrived. They actually were under the impression that I was using two different sources (I have 3 different CD/SACD front ends.)
which makes my point. because AT never took off for CD people think toslink proves fibre is bad.
In any case the TOSLINK connector is totally shirty - there is no decent clipping mechanism (like an LC connector commonly used on network fibre patch cables.) The LC connector is at least spring loaded so that the two interfaces have an airless connection.
low Mb/s over 10m and 10Gb/s over km are somewhat different requirements. toslink is fit for purpose. just...
I do. I wuss out on the power issues.
Old 28th February 2020, 04:10 PM   #454
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Audiophile Ethernet Switch
Put a decent schaefner filtered iec socket on it if the smps is internal
Audiophile Ethernet SwitchHide this!Advertise here!
Audio over ethernet and PC Ethernet controller werfi Digital Source 11 7th August 2012 09:31 AM
DIY Audiophile Series: How to Make Your Own Audiophile Quality 300B Valve Amp (4DVD) scav Swap Meet 1 12th October 2009 03:14 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Ethernet with cat5E to USB-Dac ? lykkedk Digital Source 0 1st May 2007 06:15 PM
ethernet audio device - need a switch daverave Parts 0 28th March 2007 12:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
