Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
NAIM CD5x Schematic is needed or enlighten me to fix Ch1 DEAD Audio
Old 13th June 2019, 02:40 AM   #1
Peter Qiu is offline Peter Qiu
Default NAIM CD5x Schematic is needed or enlighten me to fix Ch1 DEAD Audio
Hello All,
I got a NAIM CD5x CD Player with Ch1 DEAD (No Audio)。
I've carried out a preliminary checking on Top Side of the Printed Circuit Board:-
1) Checked working voltage of Op Amps OPA604AP and OP42 at Pin 7(+18VDC) with Pin 4 (Analog Ground)respectively。
2) I used 1KHz Audio Test Disc to confirm Signal Paths at Pin 6 of both Ch1 and Ch2 Op Amps(Output Pin of OPA604AP and OP42) with Oscilloscope and noticed that ONLY Ch1 did not show any Sinusoidal Waveform。
I guess, absence of Ch1 Output Signal was attributed by "Input Source" at Bottom side of the Printed Circuit Board Assembly....in order not to mess around bottom side of PCBA, I would appreciate it if anyone could give me a clue for fixing or provide me a schematic of NAIM CD5x。
Thanking you in advance,
Peter。
NAIM CD5x Schematic is needed or enlighten me to fix Ch1 DEAD AudioHide this!Advertise here!
PS Audio 5.0 Preamp Schematic Needed Raccoon1400 Analog Line Level 0 26th October 2018 04:42 PM
Naim Audio Scanspeak DBL tweeters - Naim Reference Set ChristianThomas Swap Meet 4 16th June 2013 06:40 PM
Naim CD5i and CD5x dueeffe Digital Source 2 25th May 2010 09:16 PM
Cary Audio V12 - Schematic - Needed Yukonsc Tubes / Valves 1 26th December 2006 06:03 PM
Enlighten me please - why does the quality of copied audio CD's deteriorate so bad? mr_push_pull Everything Else 27 21st February 2005 03:32 PM
Copyright ©1999-2019 diyAudio
