Meridians 600 series from the 90s use a Sharp GP1U521X IR receiver module, running a 38KHz carrier.
Im wondering if a Sharp GP1UX511QS might work as a modern replacement (also 38KHz).. Does anyone know?
Here are the links for the datasheets for each:
GP1U521X:
https://www.datasheetarchive.com/pdf/download.php?id=GP1U52X
GP1UX511QS
http://www.farnell.com/datasheets/128111.pdf
They look pretty similar, including the internal block diagram. One difference is the lack of shielded can the old one uses (I can re-use the can from the erratic old one).
GP1U521X:
GP1UX511QS
