Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Upgrade YBA Passion 1000 CDP
Old 9th July 2019, 02:52 PM   #21
TONI G is offline TONI G  Spain
Originally Posted by sumotan View Post
Just to add more controversy Toni G, my findings 50v caps of the same value mostly will sound better then lower voltage version.
If possible. The problem is the small space for its installation. The 25V model is the most compact I've seen in this series.
Old 9th July 2019, 02:54 PM   #22
Originally Posted by schiirrn View Post
Are you sure the elcos are bipolar? They have all the usual polarity markings.
The caps that I want to subsitute are bipolar. The indications of the sheet indicate this. The base plate itself indicates the polarity.
Old 9th July 2019, 02:58 PM   #23
The leads of your opamp decoupling caps are way to long. rather get SMD caps and solder them as close to the pins as possible.
The big problem with the components I want to replace and the extra caps that I have connected directly to the opamps is the lack of space. Even now I have doubts if it is possible to install the audio note without having to use some type of extension cable since its size is greater than that of the original caps.
Old 9th July 2019, 02:59 PM   #24
sumotan is offline sumotan  Indonesia
Hi Toni
Have tried many caps but so far not the kasei. Do wonder how they sound & if it's worth the price. Use to play with of BGs but as my listening taste evolves, I find that you can only use a sprinkle of BG cause they aren't that transparent & highs that really that good. Having said that, they do have that something that other caps will never have.
Cheers
Old 9th July 2019, 09:27 PM   #25
schiirrn is offline schiirrn  Germany
The new elcos you bought are polarized, not bipolar.
Preferred BSC? Just using a wide enough baffle.
Old 9th July 2019, 09:29 PM   #26
Maybe this is interesting for you: https://www.analog.com/media/en/trai...als/MT-101.pdf
Old 10th July 2019, 07:47 AM   #27
you're right. The electrolytic caps are polarized, not bipolar. like the originals...
Old 10th July 2019, 08:00 AM   #28
Ok. Sorry. Post #16 confused me a bit it seems.
Old 8th August 2019, 11:48 AM   #29
Well, finaly i have the upgrade
File Type: jpg 1D0C4530-D014-40BB-A04C-02E4AC5D24B7.jpg (846.0 KB, 27 views)
File Type: jpg DF6DFDA6-021B-4CA8-869A-3319D82654C0.jpg (971.9 KB, 25 views)
File Type: jpg 24C1EE07-9A9D-4D3F-9EF7-125C0AA69115.jpg (933.5 KB, 25 views)
Old 8th August 2019, 11:52 AM   #30
So is it worth the investment Tony ?
Great job btw. It's always nerve wrecking on our first couple of diys.
Cheers
Upgrade YBA Passion 1000 CDPHide this!Advertise here!
Parasound HCA 1000 upgrade srinath Solid State 6 8th July 2019 09:58 PM
Yamaha NS 1000 - Drivers Upgrade/Replacement manivasu Multi-Way 14 22nd June 2019 11:59 PM
Jolida JD 1000 Upgrade luvrockin Tubes / Valves 0 20th December 2017 10:59 PM
YBA PASSION 1000 east electronics Solid State 63 30th June 2015 10:25 AM
Parasound HCA-1000 upgrade Skorpio Solid State 15 11th August 2010 06:47 PM
Copyright ©1999-2019 diyAudio
