Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Studer D730 "Control OUE" message, won't play
Old 13th May 2019, 07:47 AM   #1
mike2016 is offline mike2016
Default Studer D730 "Control OUE" message, won't play
My D730 recently stopped playing, at first it would play then displayed the message, and all buttons would stop working and it would play until the end of the CD.
recently as soon as it powers up, the message "control oue" poped up, and nothing works.
Any idea what's causing this? I opened t up and noticed the battery was leaking, I went ahead and replaced it, same thing. no damage on the PCB or surrounding parts.
I'm thinking about to replace all the capacitors next
Old 22nd May 2019, 01:09 PM   #2
Thmartin is offline Thmartin  France
Hi there,
My D731 (same as D730 in rack format) did exactly the same thing and I managed to resurrect it. It took quite a while to locate the cause of this issue.
Problem was down to broken PCB tracks between keyboard connector and microprecessor. Tracks had been "eaten" by battery's acid.
Have a look here Audiolalies: STUDER D731 (use Google Translate) and here Studer D731 - Google Photos
Replacing the capacitors won't help for your control out problem but it's a good idea anyway, I found one dead 47F in the analog section (they're 20 years old today).
I hope it helps.
Old 22nd May 2019, 11:22 PM   #3
Thanks for the info!
in my case the battery acid didn't spread that far at all and didn't damage the tracks or penetrate the other side of the PCB. i'll have another look later on.
i also found info about IC903 / IC905 being aging and will increase voltage and damage HEF4750 , it is also mentioned in the article you sent. I ordered replacement anyway and will replace them and see if it solves the problem.
Old 23rd May 2019, 08:17 AM   #4
Thoroughly check continuity between ALL J201 pins and their destinations (MOSI, MISO, K_SEL). You may have issues under the connector base that can't be seen without removing it from PCB. A diode tester is OK to check this out.
If IC903 goes belly-up yes, it would damage HEF4750. I bought one, just to be safe, but priority is to improve those regulators cooling.
Good luck
Studer D730 "Control OUE" message, won't playHide this!Advertise here!
DAC for Studer d730 or d731 mrtakib Digital Source 32 25th February 2015 03:54 PM
Studer D730 Caps armstrongracer Digital Source 2 4th December 2014 11:03 PM
Studer D730 - Plastic Tray broken :( Help please ! studer730 Digital Source 3 20th February 2012 06:14 PM
Button problem Studer D730 Peter69 Digital Source 5 18th May 2011 06:00 PM
For sale: Studer D730 Peter69 Swap Meet 3 12th May 2008 08:41 PM
Copyright ©1999-2019 diyAudio
