Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Maybe go for Sony PS1 to avoid mechanical issues?
Old 12th April 2019, 09:26 PM   #1
AC439 is offline AC439  United States
Default Maybe go for Sony PS1 to avoid mechanical issues?
I have had three CD changers failed on me. Basically its nothing quite related to electronics but the complex loading\unloading\disc changing mechanism.
First was a Onkyo changer, then an RCA changer, few days ago was a Sony changer.
Maybe I should be using a PS1 as player. Its simple mechanically. Right ?
Old 12th April 2019, 10:34 PM   #2
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Changers are an abomination. Can't you hear it eating itself?
Old 13th April 2019, 02:45 AM   #3
phase is online now phase  United States
I went for something different altogether to get rid of mechanical problems;
Lossless SD digital turntable Player (Deluxe version) II2S coaxial output | eBay
This one is ready to go, but with a spdif output;
DC12V SD Digital Turntable Lossless Music Player Coaxial 2.8" TFT LCD MP3 FLAC | eBay
Old 13th April 2019, 05:30 AM   #4
chris719 is online now chris719  United States
I would just rip all of your CDs using ExactAudioCopy and a PC and then play it back with some kind of non-CD device like phase linked.
At least you'll have them backed up in case the discs get damaged or you can't find a CD player again at some point.
Old 13th April 2019, 07:57 AM   #5
Guerilla is offline Guerilla  Denmark
What is this? - I dont see where to put the record.
Cheers!
Allan
Old 13th April 2019, 12:40 PM   #6
I thought about this also but if I go this route, I want a player that I can mod with better coupling caps, bypass caps and op-amp rolling etc. Most available products are SMD\SMT making modding difficult. I used to use a PC to play ripped music, if I go this route again, I will put a good sound card but still mod options are not there. That's why I went back to CD players but hate to deal with mechanical issues.
Any suggestions other than those on _bay to play music files ?
Old 13th April 2019, 06:57 PM   #7
Use pc with optical out. Some laptops has too
Old 13th April 2019, 07:40 PM   #8
rhing is offline rhing  United States
rhing's Avatar
Sony Playstation 1 Model SCPH-100x consoles sound great, but the OEM laser units are no longer available, so when they go, they are gone. I wouldn’t go for the replacement units from eBay, because they simply do not work.
Rich
Old 14th April 2019, 02:17 AM   #9
Andersonix's Avatar
Find a player that uses a DAC with direct out possibility:
Mod for Oppo DV-980H: direct output from CS4361 DAC
Old 14th April 2019, 03:00 PM   #10
The DAC is what typically receives most of the modifications, and that could be a separate board after the source/player. That and the preamp/headphone amp that can be used after the DAC.
Once you buy into an over priced consumer device, the modification process will be constrained by what has been built into that already. If you build/assemble your own, it will cost around $400-500, using nice parts, and offer more flexibility to use what you want. My setup has no coupling caps, for example.
Maybe go for Sony PS1 to avoid mechanical issues?Hide this!Advertise here!
Sony TA-N55ES help with some odd issues Barwell1992 Solid State 2 19th February 2019 05:04 PM
problem with old Sony PS-LX510 linear-tracking turntable -- mechanical question Pickngrin Analogue Source 21 15th February 2015 08:53 PM
sony ps-t2 speed issues lexx21 Analogue Source 4 13th April 2014 11:04 PM
Avoid playing Sony/BMG discs on your computer DSP_Geek Everything Else 53 27th December 2005 02:25 AM
Copyright ©1999-2019 diyAudio
