Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel 991 CD transport assembly
Old 10th November 2018, 06:40 PM   #11
Danrich is offline Danrich
Danrich's Avatar
Originally Posted by Mooly View Post
The belt will have stretched only a little in practice so I would try and measure it. Cotton can be good to lay over the old one and determine the circumference that way.
How much
This isn't the one but as an example of price:
https://cpc.farnell.com/unbranded/be...ELT66?st=belts
Measure it and see what you can come up with.
One out of Malaysia for $4
Diameter 28 mm CD DVD Player Tray Belt Rubber Ring | eBay
Old 10th November 2018, 06:43 PM   #12
Mooly's Avatar
The 28mm one was just as an example of price, not size... you need to measure yours to see what is fitted.
Old 10th November 2018, 07:08 PM   #13
dacen is offline dacen  Norway
Here is the schematic diagram: ROTEL RCD-991 SM Service Manual download, schematics, eeprom, repair info for electronics experts. Just wait a minute or so until it says download. At the bottom left corner you will see the in-out signal from the drawer. It is the five pin connector K401 pin 1 and 2, probably from microswitches from the Sony drawer. Pin 4 and 5 is the motor control in and out from IC LB1641. Yes it is limit switches and on page 5 you will see the two leaf switches for in-out on board 51. S151 load out, S152 load in.
Old 10th November 2018, 07:40 PM   #14
Danrich's Avatar
Originally Posted by zgtc View Post
Sorry I don't get your question. What I mean is that, according to that site I linked to, it would not be a KSS-240 but a KSS-213B.
With a M signification it would be the whole chassis, sorry
Old 10th November 2018, 08:13 PM   #15
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
The correct rubber belt part no. is 4-927-649-01...you can find one on evilbay.
Non mai abbastanza...
Old 10th November 2018, 08:39 PM   #16
Danrich's Avatar
Thanks very much, found one shipped for $9 of sleasbay
Old 11th November 2018, 07:27 AM   #17
Mooly's Avatar
That's good but I really do suspect your problem is most likely microswitch related... which is still an easy fix.
Rotel 991 CD transport assemblyHide this!Advertise here!
Rotel RCD 855 transport problems wchwsky Digital Source 0 26th June 2014 08:55 PM
Sonic Frontiers Transport 3, pickup assembly kwatro Digital Source 1 8th May 2008 09:49 AM
Replacing transport in Rotel 855 Mikelo Digital Source 0 19th January 2005 06:09 PM
Best quality and lowest jitter Philips transport assembly? mburnstein Digital Source 8 13th January 2003 10:20 PM
