Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Toslink to SPDIF (Coaxial)
Old 19th September 2018, 10:37 PM   #1
mkafridi is offline mkafridi  Pakistan
Default Toslink to SPDIF (Coaxial)
Hello,
Can someone guide me to how I can convert Toslink (Optical) to Spdif (Coaxial)...
I need complete guidance! Like does the signal needs inversion...
I found a few on ebay but they are very expensive...
Old 20th September 2018, 07:00 AM   #2
percival007 is offline percival007  England
Default Optical to Coaxial
Toslink is just the connector, it too carries SPDIF.
What you are wanting, I think is Optical to Electrical converter.
The attached works. R1 may or may not be needed.
P.
Old 21st September 2018, 09:14 AM   #3
P.
Yes I just wanted the whole process explained!
Like have a Toslink connector but I want Coaxial... And I cannot use the output directly from the Toslink pins! Have to be a converter...
The PDF diagram does not have a coaxial out... any suggestions!
I found some info on this page S/PDIF Digital to Analogue Converter but I wanted a 2nd opinion! Maybe a buffer-less solution!
Old 21st September 2018, 05:49 PM   #4
Just connect the O/P of the circuit to a Transformer, one like this for example...................
https://uk.farnell.com/murata-power-...06h/dp/1362398
and then a BNC or an RCA connector to the secondary winding.
P.
Old 21st September 2018, 06:30 PM   #5
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
A converter is the worst of solutions. Opening the device and adapt it straight to BNC 75 Ohm SPDIF output is the best choice. I do this regularly and SPDIF (although still being a bag of hurt) performs better over BNC than over Toslink. Only drawback for many is the need to drill a hole in the back of the device which it in fact quite simple. Some talk gibberish about "lower resale value" but better performance is why we are here for isn't it?
Posting the pdf really would help.
It's only audio. Member of the non modular PCB design committee
Old 22nd September 2018, 12:21 PM   #6
No I am trying to use PC in my car... my processor only accepts coaxial, but my soundcard (Asus dx) only has optical out...
Or should i buy a USB to coaxial like: 1Pcs PCM2704 USB DAC to S/PDIF Decoder Board Module Analog Output -in Replacement Parts & Accessories from Consumer Electronics on Aliexpress.com | Alibaba Group
Or should I buy: HIFI USB Sound Card DAC Audio USB To SPDIF PCM2704 Digital Analog SPDIF Output Audio Converter DAC Decoder PRO Converter-in Digital-to-Analog Converter from Consumer Electronics on Aliexpress.com | Alibaba Group
I like the first one cause it has optical and coaxial both... 2nd board has buffer, better crystal and output isolation (transformer)
Also what is the advantage of using active crystal over a simple 2 legged crystal?
Old 22nd September 2018, 12:31 PM   #7
P.
What if I don't use a transformer and buffer... most circuits use inverted buffers... Transformer is good for isolation but what advantage does the buffer has?
Old 24th September 2018, 06:14 AM   #8
jean-paul's Avatar
So you need to make a new coaxial output on the sound card, right?
Old 25th September 2018, 02:33 PM   #9
Well yes if it is a better option than using USB -> Coaxial!
Toslink to SPDIF (Coaxial)Hide this!Advertise here!
Converting Toslink Digital in to a Coaxial SPDIF Digital Input on Theta DAC dtm1962 Digital Line Level 1 15th June 2018 07:12 PM
Spdif coaxial, toslink or aes/ebu ? ginetto61 The Lounge 24 31st August 2016 10:06 PM
SPDIF coaxial to Toslink Converter lank007 Digital Source 7 3rd December 2005 04:10 AM
Toslink vs Coaxial Ruach Digital Source 0 20th September 2005 04:56 AM
Toslink Vs Coaxial XTAL Digital Source 4 26th March 2004 03:51 PM
