Hi
If you search eBay for Digital SPDIF to Analog,
2 results that repeat themselves quite a lot are these:
The first:
Outputs 2 RCA (without 3.5mm):
The second:
Outputs 2 RCA and a 3.5mm:
As can be seen, those 2 models are pretty similar,
the only (external) difference is that the first is a little bit smaller, and without 3.5mm,
and the second is slightly wider, and has 3.5mm in addition to 2 RCA.
Does anyone here have them, and know what Chip is inside?
Also I would like to ask if there's a difference in the chip between the first and second model..
The reason I ask this, is because the second model (with 3.5mm) is about 10$,
while the one without the 3.5mm is aprox. 4$..
I assume this difference is not due to the cost of a 3.5mm socket..
So there's a high chance that there's a difference in the chip inside..
Hopefully someone here has them and knows.
Thank you
The first:
The second:
Thank you
This auction for the top model shows the specifications as
Specifications
Input Audio: Coaxial or Toslink digital audio
Output Audio: L/R audio + 3.5mm jack audio
Input audio connector: 1 x Toslink, 1 x RCA (Coaxial)
Output audio connector: 2 x RCA(R/L), 1 x 3.5mm audio jack
Sampling rate: 32, 44.1, 48 , 96 and 192 KHz
Chipset: cirrus logic 8416
Power input: AC 100-240V 50/60Hz
Output: DC 5V
Plug standard: US/EU/UK/AU plug
Size(L-W-H): 51X41X26MM
Weight (Net): 78g
Specifications
Output: DC 5V
Weight (Net): 78g
For the second people seem to be using the specs from PROZOR DAC01 Stereo Audio R/L Converter Adapter | prozoreu. Maybe drop them an email ?
The price difference could be the extra circuitry for the amplifier circuit for the headphones and jack, as well as the larger case.
Interesting.The price difference could be the extra circuitry for the amplifier circuit for the headphones and jack, as well as the larger case.
They did not specify that the 3.5mm socket with the headphones symbol beneath it, is a headphones amplifier out.
My guess is that it's simply a Line Out, similar to the 2RCA aside it..
But it might indeed be with a headphones amplifier..
Thank you for the tip..The small one is pleasant to listen to. But it doesn't have much detail. If you need a cheap dac for the TV it's good. Not great as your main dac though.
Will not buy it in that case..
second one uses DAC CS4344, SPDIF converter which i forget, but something standard and very easy to find in google, usually used together with this DAC, and unknown op-amp. there is a schematic easy to find using google. on op-amp output there are only some not so good series capacitors with probably wrong values. very easy to replace them, add 2 resistors to create high pass filter and another 2 stopper resistors. in original didn't sound good when connected directly to amplifier (completely wrong output). with simple rework sounded much better. well, not audiophile, but really very good for its price.
in original RCA and phone out are just in parallel, as probably can be seen on pictures. if my memory serves me well, 'suitable' for headphones in 600 ohm range because of output caps.
- Digital Source
- What Chip is inside these 2 Digital (Toslink+Coaxial) to Analog (2RCA) Converters?
