Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DAC + headphone amplifier based on Marantz DR4050
Old 3rd October 2018, 12:55 PM   #31
rfbrw is offline rfbrw
The gain of the TDA1308 is fixed. The UDA1320 has a volume control. You can connect before the 22k resistors but you will not have any control.
Old 3rd October 2018, 07:10 PM   #32
peterpl is offline peterpl  Poland
The sound from CD is not volume controlled it just playing loudly and that's it. What about adding a stereo potentiometer just before headphones socket?
Old 4th October 2018, 07:48 PM   #33
Best after a switch but before the amp.
Old 5th November 2018, 10:56 AM   #34
Finally I have took out the CDR mechanism as because of broken laser it will not be used. I took out connections as described in post #27 and connected to them new TDA1308 based on schematics in pdf file. That circuit is supplied 5V from power supply unit filtered additionally with 10K uF condenser. Sound is the same as from ther other TDA1308 on CD part ( I just wanted to leave CD part untouched). Now I will try to adapt external DAC and connect it to Marantz's sockets. By removing CDR mechanism there is space when you lift left drawer cover. That place could be good to put a slider potentiometer which would normally be hidden by that cover.
DAC + headphone amplifier based on Marantz DR4050Hide this!Advertise here!
EAMP08 RC headphone amplifier. TPA6120 based. Frex Headphone Systems 15 21st February 2016 12:26 PM
LME49600 based headphone amplifier jpak Swap Meet 2 19th January 2015 10:16 PM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 05:36 PM
How to build a TPA6120 based headphone amplifier? sxulocktor Headphone Systems 9 20th July 2011 01:46 PM
OP Amp based headphone amplifier. zebra100 Headphone Systems 32 1st October 2008 10:00 AM
Copyright ©1999-2019 diyAudio
