Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DAC + headphone amplifier based on Marantz DR4050
Old 13th September 2018, 06:49 PM   #11
rfbrw is offline rfbrw
You need something that looks like the RF eye pattern. I have no idea if it will work.
Old 13th September 2018, 07:25 PM   #12
peterpl is offline peterpl  Poland
It seems complicated to generate such a signal, can't we cheat the DASP ?
Old 13th September 2018, 07:39 PM   #13
Another idea is to get that signal out of CD part. CDR60 will think that It's own laser is working. What do you think?
Old 13th September 2018, 11:48 PM   #14
That may work. The signal at the SAA7324 looks the same as the one at the SAA7392. Focus and all the correction stuff probably won't work but it may be enough.
Old 14th September 2018, 09:12 AM   #15
Fine, but now we should solve how to switch on CD while CDR is working. They can work together only when copying from CD but to do that CDR has to work properly, which it didn't.
I still think why it is not possible to make MCF5244 ( DASP) working independently.
Another idea is to treat external signal coming to DASP as HF signal and connect e.g EXT-OPT_IN with HFIN.
Old 14th September 2018, 03:12 PM   #16
Generally to make CDR/DAC working by imposing working of CD part is not a good idea. But I suddenly noticed cheap computer or standalone CDR writers. Would it be possible to get an RF signal from such a writer ? I think a schematics would be needed.
Old 14th September 2018, 06:26 PM   #17
How about a replacement OPU ?
Old 14th September 2018, 07:24 PM   #18
Yes... we came to the point we have started from.
I am not the only guy willing to use Marantz DRXXXX recorder as DAC because demand for copying CDs is decreasing. So people are using it as DAC putting a blank CDR, pressing a record buton and letting laser to be on by several hours. This sooner or later damages the OPU and I think that OPU in my recorder was worn out due to the same reason.
OPU in e-bay is ca 50 but looking on service manual you have to adjust the current which is not simple.
The only solution is to be able to make the DASP = MCF5244 working independently.
I was looking for a schematics of that IC but with no success.
Unless someone reading this topic will have a solution for the DASP we should stop.
Old 15th September 2018, 12:30 AM   #19
You are probably right on stopping. The DASP has parallel address and data busses, I2C and JTAG. Disregarding JTAG, you would have to sniff the I2C bus and maybe the parallel busses. That is a lot of work.
Old 22nd September 2018, 11:58 AM   #20
I wanted to use at least Marantz's headphone amplifier as it is playing very well. I have noticed that CD's analog out goes to headphone amplifier IC 7408 = NJM4556D via switch IC7407 = 74HC4053D. So I have connected CDR analog in directly to CDR's CD analog in. When switched power, there's no music heard. You have to initialize it by playing a disk in CD ( maybe it switches IC7407). Then you may take the disk out as the sound from external source connected to CDR analog in is being heard. But..... it's too silent opposite to a sound from CD which I may call "too loud". Don't know why. The sound from CD goes first through ap amp IC7120 = LM833D or TDA1308T ( difference between component list and schematics). But sound from CDR desn't go through LM833D ( IC 7409) in order to go to IC 7408 ( but maybe there's mistake on the drawing) Do you think I should connect CDR analog in directly with pin 3 and 5 of IC 7120 on CD board ?
DAC + headphone amplifier based on Marantz DR4050Hide this!Advertise here!
EAMP08 RC headphone amplifier. TPA6120 based. Frex Headphone Systems 15 21st February 2016 11:26 AM
LME49600 based headphone amplifier jpak Swap Meet 2 19th January 2015 09:16 PM
Discrete op amp headphone amplifier module, based on Marantz rjm Headphone Systems 4 10th November 2013 04:36 PM
How to build a TPA6120 based headphone amplifier? sxulocktor Headphone Systems 9 20th July 2011 12:46 PM
OP Amp based headphone amplifier. zebra100 Headphone Systems 32 1st October 2008 09:00 AM
