Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
How can you connect new BT 4.2 WTS audio receiver module with TPA3118 mono noiseless
Old 22nd July 2018, 09:06 PM   #21
oxl is offline oxl  Denmark
I decided to try to use this CSRA64215 APTXLL Stereo Bluetooth 4.2 Audio Receiver Board TWS Car Bluetooth Receiver Module For Amplifier Speaker DIY together with the TPA3118 PBTL mono 60W.
Can I make the CSRA64215 control the mute function of the TPA3118, so it mutes the amp when there is no audio from the BT module (paused or muted) ? Does the TPA3118 still use significant power when muted (is it still amplifying) ?
Aiyima CSRA64215 APTXLL Stereo Bluetooth 4.2 Audio Receiver Board TWS Car Bluetooth Receiver Module For Amplifier Speaker DIY-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Old 3rd August 2018, 09:25 AM   #22
The BT has a Mute pin that goes logical high when there is an audio signal (otherwise logical low). How can I use this with the AMP (Sanwu TPA3118 PBTL mono) Mute pins ?
Old 4th August 2018, 11:20 AM   #23
BT mono AMP 60W (35x75 mm)
Old 8th August 2018, 04:19 PM   #24
Nenola is offline Nenola  Finland
The amplifier section is mono but you only get left channel signal from the BT-module. Some recordings might sound a bit weird. Or am I missing something here?
Old 8th August 2018, 09:54 PM   #25
It is because I am using two of these with TWS (would be easier if I could find some with CSRA64110 - composite mono)
Old 16th August 2018, 12:40 PM   #26
Or I could connect the two outputs via two 100 ohm resistors to input
Old 24th August 2018, 10:30 PM   #27
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I just finished a project doing a similar thing.
I dropped 12 volts down to 5 volts for the BT using 7805 wit hheatsink and it worked fine. I had a few problems connecting Bluetooth to pc but managed in the end.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
How can you connect new BT 4.2 WTS audio receiver module with TPA3118 mono noiselessHide this!Advertise here!
any way to connect old school stereo receiver to A/V receiver silentecho77 Analog Line Level 19 5th December 2017 01:16 AM
WM8805 Audio-GD spdif receiver module for a NFB3.33 DAC andreaemme Digital Line Level 6 11th August 2017 04:42 PM
WM8805 Audio-GD spdif receiver module for a NFB3.33 DAC andreaemme Digital Line Level 0 7th August 2017 06:04 PM
TPA3118 Mono Board Doesn't Work rcbuck Class D 5 3rd August 2016 10:08 PM
connect IR receiver AndrewT Analog Line Level 32 21st March 2011 06:09 PM
