Music Fedelity A3.2 CD player no sound out of line and digital output
Administrator
Joined 2007
The DAC may be the PCM1738 in which case the data sheet for the chip will piece together the expected voltages and signals expected:
http://www.ti.com/lit/ds/symlink/pcm1738.pdf
Check for obvious stuff first such as whether there is a mute facility... once muted it may remember the setting. Should be easy to identify any muting at the final analogue stages, whether relay or transistor based.
