Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CD100 won't play disc
Old 11th July 2019, 04:11 PM   #11
anatech is offline anatech  Canada
anatech's Avatar
Hi wyan,
Hi, I am trying to re-cap CD100
Why? Is this a problem fix, or are you just doing it "because"?
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 11th July 2019, 08:09 PM   #12
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by partsman View Post
so will hope it stays as it is.
Hope does not solve ageing parts. Just replace the caps or have them replaced by someone who has the skills.
It's only audio. Member of the non modular PCB design committee
Old 12th July 2019, 03:54 AM   #13
wyan is offline wyan
Hi, Rudiger,
Thanks. I thought about film capacitor but one with 15uf would be really big. Can I go smaller? What normal cap would you recommend? Since I am about to replace all the electrolytic caps, I would rather also replace this one as well. As for the axial caps, I will leave them alone. Thanks.
WYAN
Old 12th July 2019, 04:47 AM   #14
jean-paul's Avatar
If you mean cap 2217 (15 F nonpolar cap), it is replacable by a 3.3 uF polar cap. Thus, since progress has been made with regards to size, you can even use a film cap 3.3 F Wima MKS2 in 5 mm pitch. This cap 2217 regularly fails and was changed in later production CD100. Please see info here:
PHILIPS CD 100+101 Player Netzteil Elkos VISHAY power supply recap recapping kit | eBay
* Axial caps that are old and worn out also need to be replaced. These CD players are 35 years old, don't gamble and hope you can get away with it.
Old 12th July 2019, 05:15 AM   #15
Thanks. The CD100 I have has philips 3.3uf in 2217 so I am going to replace it with another. Easy swap. Not sure about 2214 though. I will consider axial caps as well. The CD player is very easy to disassemble. Just need to remember the correct connections (Philips alternate those connectors with black/white color so not so hard either).
Old 12th July 2019, 05:16 AM   #16
jean-paul's Avatar
If you change caps AND resolder the complete device it will last for another 35 years I guess
Old 12th July 2019, 05:17 AM   #17
Originally Posted by anatech View Post
Hi wyan,
-Chris
It sit in the closet for two years and when I took it out a few days ago it would not play. It rotated a few turns and stopped. I powered it on for a few hours and it worked again. I guess I still need to replace the caps. The CD player is easy to disassemble any way and I always need to order caps now and then with various projects.
Old 12th July 2019, 05:20 AM   #18
I certainly hope so. They say the CDM0 laser actually last very long. And it plays lovely. Maybe not so many details as modern couterparts but it has certain taste that draws.
Old 12th July 2019, 05:25 AM   #19
jean-paul's Avatar
It has 14 bit conversion which is the way to go in digital audio
Philips CD100 won't play discHide this!Advertise here!
cd100 philips panamera Digital Source 2 12th September 2014 01:06 PM
Philips CD100 Jimmyhaflinger Digital Source 34 16th December 2013 06:38 PM
philips CD100 mr.captain2000 Digital Source 6 6th January 2008 08:34 AM
Help on Philips CD100 khjen Digital Source 2 6th June 2007 05:17 AM
Philips CD100/00 & CD100/30? eelekim Digital Source 4 1st February 2006 08:59 AM
Copyright ©1999-2019 diyAudio
