Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
HDMI to analog
HDMI to analog
Old 15th May 2018, 11:41 PM   #21
Pano is online now Pano  United States
Pano's Avatar
HDMI to analog
^ Post above sums it up perfectly. Use the optical out to a good DAC. You have far, far more choice with optical than with HDMI.
Take the Speaker Voltage Test!
Old 16th May 2018, 12:31 AM   #22
stratus46 is offline stratus46  United States
Originally Posted by gadut View Post
correct Pano, if no spdif then no other choice rather than replace that old Hafler into newer AVR
I'm cheap and do not want focus on HT yet, hence i bought this small toy
Audio 5.1CH AC3 DTS Digital Sound Decoder Optical SPDIF Coaxial to 6RCA w/Cable | eBay
up to AC3 can be decoded, while newer codec like DTS HD, TrueHD, Atmos is dead silence
I use one of those in my cheapy 5.1 system. It also needed a 6 channel volume control and 6 channel class D amp (TPA3116). The unit you reference had quite a bit of background noise for the switching supply. Changing to a linear 5 Volt supply was a dramatic improvement.
FYI for about $40 you can get the same 6 channel analog output but with HDMI in / out rather than optical.
Old 16th May 2018, 02:22 AM   #23
gadut is offline gadut  Indonesia
gadut's Avatar
Originally Posted by Lubbock023 View Post
The ultra 4K DVD/CD player is LG UBK90. HDMI 1 goes from my DIRECTV Genie to my tv for video and cheap audio (tv, Netflix, etc). HDMI 2 from DVD. The player has a separate HDMI audio out for HDMI 2 that I run to my preamp. Well, I did with my previous Blu-ray DVD player that had RCA output. I don't have surround, just two channels to my main speakers. So, all I need is something that will convert my HDMI audio out from the DVD to 2 channel RCA L/R, but again, retaining sound quality is an absolute.
decent sound quality sometimes relates to $$$ spend. dont expect too much on a product <$50.
btw seems your LG has optical out then you can plug it into the decoder i mentioned. Or another option which I'm using now, get the analog out from your TV which is usually headphone out then connect it your Hafler. My sony tv still give headphone out, LG does the same, but Samsung new generation already remove it. Watching tv and get decent audio from heaphone out to mauro penasa which powers my 3way floorstand is very satisfaying, forget about soundbar
I bought it to get the experience on multichannel, i never had any AVR yet. my setup was :
- LR thru my main audio chain : dcb1 - class a amps - big OB
- center : class d powers my alpair 10p
- surround : mauro penasa powers 3way floorstand
I admit watching bluray movie ac3 encoded has different experience, but the sound was muffled and compressed if i compared to DTS HD version which i watched on stereo only. I decided not to use it anymore while saving money for proper AVR
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 16th May 2018, 02:39 PM   #24
Lubbock023 is offline Lubbock023
Are there any ultra 4K DVD players on the market with analog audio output?
Old 16th May 2018, 02:54 PM   #25
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Of course: Panasonic DMP-UB900 for example.
Lession learned? Never ever let a woman go buy technical gear! Women just chose by the looks...
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 16th May 2018, 04:08 PM   #26
Pars is offline Pars  United States
Pars's Avatar
Also Oppo. I know they are getting out of this but seem to be set up for continued support, so I personally wouldn’t be bothered by that.
Old 28th May 2018, 08:23 AM   #27
Dave is offline Dave  New Zealand
HDMI to analog
One of these will get you an SPDIF signal from the HDMI which you can pass to a DAC of your choice.
Audio De-Embedder with 3D Support
Supports up to 192/24
HDMI to analogHide this!Advertise here!
HDMI DAC for analog 7.1 output Fusion916 Digital Line Level 10 11th July 2014 04:38 PM
*Newb* HDMI --> Analog being performed by the TV, is this bad? brandontw Digital Source 4 10th January 2013 08:50 PM
Convert HDMI audio signal to 5.1 analog audio TMStamp Digital Line Level 3 2nd October 2012 06:53 PM
HDMI to analog, or multiple analog channel mixer TAYLOR1337 Digital Source 1 12th September 2011 10:17 PM
hdmi to analog? 8 CH USB DAC? malle Digital Line Level 5 9th January 2009 10:30 PM
Copyright ©1999-2019 diyAudio
