Philips CD960 problems
Hi, I got the problems with my CD960. When the power is turned on, the spin motor turns counterclockwise a while then stop and the laser head moved up and down several times with weak light. Does anyone know what is the problem with my CD960(cdm1)?
download the service manual and here is the area you need to check : +12 and -12.
As other also suggested, please measure the power supply voltages. You will need a service manual or at least the circuit diagram. Marantz used to have the good habit of packing the schematic diagram with their appliances, and Philips CD-960 is identical to Marantz CD94.
BTW how did you manage to break those diodes? :confused:
:eek: The 1k is the laser current setting. It does not need any adjustment. If absolutely necessary, follow the service manual:
Play the test disc
Measure voltage on R309
Adjust VR 3180 for 575 mV +/-75 mV on R309
If you don't have a test disc, better not to touch it.
Administrator
Joined 2007
You are really not understanding the issue here.
A new laser diode has a very wide tolerance on the current required to produce a given optical output and this means the correct current could be anywhere from say 45 to 65 milliamps as an example. That might be a range of 300 to 600 ohms on the preset.
It is not possible to give a typical figure simply because there isn't one.
