Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Technics SL-P990 disc wont spin unless i help it ..
Old 12th May 2019, 12:40 PM   #41
PC91 is offline PC91  Argentina
For anyone still looking for a fix to the p990, yesterday i got fixed a japanese import model (all black really cool). The IC was blown so i replaced the complete motor with the one of a P520, it wont physically fit without resoldering the bigger caps that are on a separate PCB in another position and removing the alignment pins on the p990 mechanism, also the connector is different but you can re use the original wiring, it uses the same cables colors.
Also disc height might need a recalibration.
On a side note every SOALP1200 machine is a good donor for them (check vasiltech for the models) it is strongly recommended that the new motor also gets a recap. Also Soalp320 motor might be compatible too, i'm actually looking for one to use it on a second p990 with the same failure
Old 14th May 2019, 08:58 PM   #42
MaccAu is offline MaccAu  Australia
MaccAu's Avatar
Send a message via AIM to MaccAu Send a message via MSN to MaccAu Send a message via Yahoo to MaccAu Technics SL-P990 disc wont spin unless i help it ..
Thats diffferent PC91, a new mechanism, you have another P990 with the same failure , is s shame, but I think the problem is more common that i thought
1980s are rad
Old 14th May 2019, 10:46 PM   #43
Yes, different but schematically the same if the mounting points are in the same place it can work.
P520 also had a very different mechanism but with little effort it was alive.
Also yes... is quite a common problem on the 990 but not so much on the other donor mechanisms
Old 16th May 2019, 09:30 PM   #44
MaccAu's Avatar
least there is another fix for the P990 mechanism with the P520 donoars. It must be the P990 IC that must fail, its good and brushless design but is let down with the IC
1980s are rad
Old 18th May 2019, 01:58 PM   #45
I think the problem is center on the capacitors brand/model on the P990 that don't hold very well to time and leaks.
There are small SMD caps which ail in every technics model that has brushless but this won't kill the IC.
On the other hand there are 3 big caps on the motor, on the p990 the leak in a very nasty way stressing the IC and making it fail.
On other models this caps are from other brands and in the Soalp1200 mechanism is even on a different PCB which completely avoids leaking damage
Old 18th May 2019, 03:55 PM   #46
Mr Snapper is offline Mr Snapper
I think it was found that the motor chip could overheat and fail. At some point, Technics added a small heatsink to the chip and it was made available as a service mod.
Old 19th May 2019, 01:38 AM   #47
This is what it looks like in the SL-P1200:IMG_20190303_16402.jpg
Old 20th May 2019, 09:16 AM   #48
MaccAu's Avatar
Thanks for the photo MrSnapper, i bet there is not many P1200 with mech issues with the heatsink of the motor chip, if only they had it on the P990 which was a high end player for home use.
I got a spare board but if find a chip working someday will instal heatsink on it
1980s are rad
Old 20th May 2019, 05:23 PM   #49
Typically, it's the two surface mount capacitors that fail.
See you're posting on AOS...
Old 20th May 2019, 10:00 PM   #50
MaccAu's Avatar
Hi MrSnapper,
Yes i am on AOS, hoping to get a few bites on the phono question. I had a few threads there , one was the P990. I think i have seen you there, same user name?
Maybe my IC migth be okay on the spareboard, the other i smelt burning so its done.
1980s are rad
Technics SL-P990 disc wont spin unless i help it ..Hide this!Advertise here!
Technics SL-P990 Skipping- Laser adjustment? matski Digital Source 17 13th March 2018 07:58 PM
quad 99 CDP: disc do not spin ludofrenchie Digital Source 2 6th September 2015 05:53 PM
Beosound Overture CD wont spin some help humb11 Digital Source 20 4th March 2015 01:17 PM
Technics SL-P990 MaccAu Digital Source 2 28th November 2014 07:32 PM
Quad67 cDP wont spin up andjur78 Digital Source 6 13th February 2006 06:23 AM
Copyright ©1999-2019 diyAudio
