Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD6000 HDAM DC offset
Thread Tools
Old 23rd October 2015, 06:30 PM   #1
dragonweed is offline dragonweed  Hungary
Banned
Default Marantz CD6000 HDAM DC offset
Hi there!
My CD 6000 (Not OSE) developed a problem. I use it DC coupled, the output coupling caps bypassed, and recently one channel shows insreased DC on the output terminals.
The good channel is 4.6mV, the other 128mV. It is the HDAM module, because on its inputs there is 1.2 and 1.4mV respectively. The other module is OK. I guess it is the input diff. FET pair what is causing the problem. Is there any idea how can I fix it, without replacing the FET-s?
The module is all SMD parts, and is is a PITA to work on it.
Old 23rd October 2015, 07:09 PM   #2
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
It's not correct to view the channel with the 128mV offset as necessarily indicating that something is wrong with that module. It may simply indicate a very normal degree of D.C. offset due to temperature drift, or aging parts, or some natural parameter mismatch. You are attempting to D.C. couple a circuit that was not designed for that, else, Marantz likely wouldn't have added the cost of output coupling capacitors. I can't think of too many discrete op-amp circuits featuring a transconductance output node VAS stage (such as does this HDAM circuit) that don't utilize either a D.C. blocking output capacitor, or an active D.C. servo circuit.
Old 23rd October 2015, 07:34 PM   #3
Banned
I completely agree with you, it is only my nitpicking stupidity that wants everything perfect... But really: that thing (and all audio stuff) sounds SSooo much better without ANY coupling caps in the signal path. That's why I am trying to get rid of them. Anyway, I will try a small (100 ohm) trimpot between the two sources of the FET-s, maybe it will help. (it did in my power amp, similar diff. ip stage with JFET-s). Luckily the HDAM module -beneath the metal shield- is not smd, but discrete parts composed.
Old 23rd October 2015, 08:01 PM   #4
Ken Newton's Avatar
Before you give up on A.C. coupling capacitors, I can report excellent results with Black Gate type 'N' (bipolar) 4.7uF electroytics. Yes, electrolytics. The subjective clarity was much superior to that of some Clarity Cap brand polypropylene film units I had tried there. I doubt that the Black Gate can be beat should you require larger value units, such as the 220uF that Marantz specifies in the schematic. While no longer in production, some stock still remains at a few audio parts suppliers, at clearance prices in some cases.
Also, Nelson Pass reports very low distortion with Elna Silmic II e-lytics, these are in current production, but I have no personal experience with them.
Old 24th October 2015, 11:51 AM   #5
Mooly's Avatar
I wouldn't add a trimmer, the resistance will lower the transconductance of the whole input stage. Not a price worth paying.
  Reply to this post
Marantz CD6000 HDAM DC offsetHide this!Advertise here!
marantz 16 bias/dc offset help lavane Solid State 0 29th October 2013 03:51 AM
Marantz Model 16 biasing and DC offset pancaQe Solid State 0 22nd June 2013 09:50 PM
Marantz HDAM toufu Solid State 1 2nd February 2012 06:27 PM
Marantz 4270 DC offset and bias adjustment The Donk! Solid State 6 8th February 2010 03:53 PM
Bias and DC Offset Pots Marantz 2285B DreadPirate Solid State 6 9th August 2009 10:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
