Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Raspberry Pi DAC Help!
Old 22nd October 2015, 08:20 PM   #11
pamantea is offline pamantea  Canada
Originally Posted by sangram View Post
This is one I was considering at one point in time (still am!):
Acrylic Case and HIFI DiGi + Digital Sound Card I2S SPDIF Optical Kit for Raspberry Pi 2 / B+ / A+ - Free Shipping - DealExtreme
The jumper near the power regulator can be removed. Some DIY is needed as it's also an interference suppressor. You can use that point to inject some cleaner power.
The Hifiberry Pro in your list specifically lists external power supply as a feature too! Not sure how it's implemented, but if you're a paying customer they will tell you how to go about it. As the page says, it will require soldering and void warranty, but you can't expect board makers to honour warranty for external (DIY!!) supplies.
I like the case!
I have been thinking, can the Raspberrry pi DAC be used passively? By that I mean can I connect via usb my iphone 4s to the Raspberry pi and play and control the music through the iPhone? Basically, I would like the digital signal to go from the phone, through the raspberry pi DAC, convert to analog, then to the amp. Is that possible?
Or, must I connect it to the internet via wifi and have a USB data drive with the music on it?
Old 22nd October 2015, 11:02 PM   #12
surfstu is offline surfstu  United Kingdom
I have a raspberry PI with the i2s HIfiberry Dac attached, it very small as the DAC circuit board sits on top of the Pi. I have the Power supply that came with the Pi - just an average wall plug Job, - sounds fantastic.
Volumio is on the Pi and I mainly use MPD as Volumio willfind any music in your home that is on a shared drive and connected to your network.
ALSO- and I think you will like this, my girlfriend occasionally has her Macbook and Volumio will automatically play her itunes over airplay. my step son occaisonally turns up with his iphone and volumio will pick up music from his phone and play it through the Pi.
So the answer to most of your questions is YES
And it's mostly plug and play to setup
Stu
Old 22nd October 2015, 11:17 PM   #13
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Wow! As good as a Naim CD5i? High praise.
Originally Posted by timbarnes View Post
The easiest way is an I2S DAC - I have the PiCobber and the HiFiBerry on two different Raspberry Pis (both first generation). I run Volumio on the Pis, and MPod on my iPhone to control. The music is on a USB disk on my wireless router, but you can also put the disk directly on the Pi.
It works well, both DACs sound great - at least as good as my Naim CD player, and it's nice having remote control.
The Naim players (every last one of them that I have heard and I've heard a few...) sound great. If the Pi DAC/Raspberry Pi sounds anywhere near as good then quite a complement.
stew -"A sane man in an insane world appears insane."
Old 23rd October 2015, 01:26 AM   #14
linuxfan is offline linuxfan  Australia
I won't offer any advice about choice of DAC, or power supply, but I comment on your configuration questions:
Originally Posted by pamantea View Post
iPhone->usb -> raspberry pi -> raspberry pi DAC addon -> analog to LM3875 -> speakers
This idea is fundamentally wrong. Since you have specified a direct USB connection from the iPhone, this means that the iPhone is the digital audio transport, and the next component in the chain should be a DAC. In this case the Raspberry Pi, which (amongst other things) is also a digital transport, is completely redundant.
If you're happy to continue to use your iPhone as primary playback device, with direct USB cable connection, then it's certainly possible to connect directly from iPhone to a DAC, then to amplifier ... more information later. A Raspberry Pi is completely unnecessary. By adding an external DAC to the iPhone you will, depending on how good the DAC is, likely achieve a SQ improvement. Bear in mind that the music files on the iPhone are compressed, so this is a limiting factor.
But is this what you want? I suggest you sit down and do some thinking and reading on the subject. Do you want your iPhone to be the home music player? Or do you want to set up a music server/network audio system, accessing your iTunes collection from your desktop or laptop computer?
If yes to the 2nd option, then sure, a Raspberry Pi would be a decent choice of music server ... or actually music renderer, if it was to be configured to receive Airplay streams from your iTunes computer (as surfstu mentioned).
Back to the iPhone option: direct USB-audio connections from iPhone/iPad became easy only from the release of iOS7, so that's the base requirment for your iPhone. Prior to iOS7 the digital audio was encrypted, and could only be decrypted by Apple-licensed hardware, which was usually quite expensive. Even with iOS7 conventional Apple USB cables will not do the job - instead you need an Apple USB Camera Connection cable. Also you must be careful that if the DAC draws power from the USB cable, that this does not exceed the current limit of the iPhone or iPad. Good information here -
How to Connect Android, iPad, or iPhone to a DAC | JDS Labs Blog
You need to decide which path you want to take.
Old 23rd October 2015, 03:37 AM   #15
Stu
That is a really convenient setting! How does Volumio know to search other devices like your step sons phone and girlfriends macbook? Very cool software!
Old 23rd October 2015, 03:46 AM   #16
djonesii is offline djonesii  United States
I have had very poor luck with getting Volumio to do what I want, which is streaming internet radio, AND a music server.
For that task, I have been using a squeezeplug pi setup.
SqueezePlug
This gives me a nice interface on my phone, and as long as I mount the Harddrives, I'm good to go.
Only way what I have found to reliably stream internet and serve up hard disk stuff.
Been toying with a windows pad set up as microCenter has them on for $79, and using I heart radio, but have not done the yet.
For me, the hardest part has been chasing hum out of the integrated amps that I put them in!
Dave
Old 23rd October 2015, 08:06 AM   #17
@pamantea. .. volumio on the pi has airplay built in, which means iTunes devices can see it and use it to stream music to. No need for USB cable either, I presume you have a WiFi router that the pi and your phone can connect to?
Old 25th October 2015, 12:07 AM   #18
Great information, thank you! I have purchased an IQaudio DAC+, an official raspberry pi wifi dongle, and a power supply too.
I cant wait to get everything in now!
Old 25th October 2015, 01:34 AM   #19
OK, that's good. You have obviously done some thinking, and made the decision to go with a music server/renderer.
There are several options now available to you in terms of how the RPi will access a music library, but it's clear you already have an iTunes music collection, presumably on a desktop/laptop computer, so the choice is rather straightforward to have iTunes act as the music library and Airplay server - as has been mentioned.
What hasn't been fully discussed is how you now control playback -
i) you can directly use the iTunes interface on your desktop/laptop computer.
or
ii) you can use your iPhone as a controller, by installing the "Remote" app -
Apps - Remote - Apple (AU)
This latter option is somewhat ironic, since your iPhone will be remotely controlling the same music collection which the iPhone already contains internally!
Alternatively you could buy a different (Apple) controller device, such as an iPad, thus freeing your iPhone for what it was primarily designed to do - make and receive phone calls!
Of course an iPad is a rather expensive device to use purely as a music controller, but it's also possible to do the same thing with an Android phone or tablet, with a suitable Android app installed, such as "Retune" -
https://play.google.com/store/apps/d...c.retune&hl=en
or "Remote for iTunes" -
https://play.google.com/store/apps/d....hftunes&hl=en
Old 25th October 2015, 07:43 AM   #20
jochems is offline jochems  Netherlands
After some initial experiments with volumio I now have a squeezebox implementation (SqueezePlug) running on my Pi. It gives much more control over the music library, better playlist capabilities and there are some apps out there (I use iPeng) that are provide remote control on par (or better) than some of the high-end stuff from Linn and Naim.
My current hardware setup:
RPi2 > Hifiberry DiGi+ > dCS Puccini
This setup comes frightingly close to the Auralic Aries LE I tried as renderer.
Experiments with USB and SPDIF rto various DACs (Audio GD NFB-2, Cambridge Dacmagic+) showed a significant difference. SPDIF via the Digi+ sounded much better than USB. So much better that I sincerly doubt the USB audio implementation on the Pi....
I now plan to take it one step further:
RPi > I2S FiFo (from Ian) > dCS Puccini
Let's see if this can beat the superb Auralic Aries with femto clock that still sounds significantly better than the Pi/Digi+.
But mind you, the Pi solution is only 1/18 of the cost....
Raspberry Pi DAC Help!Hide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
Sound quality of Raspberry PI 2+ I2S DAC bading PC Based 36 11th October 2015 01:45 PM
Raspberry Pi DAC options recommendations?? JonesySA Digital Line Level 11 1st May 2015 11:14 AM
Linear power supply for DAC/Raspberry Pi etc. jean-paul Digital Source 0 30th April 2015 10:56 AM
Opus DAC with Raspberry Pi Type B kinku Digital Line Level 8 11th April 2015 12:11 AM
Copyright ©1999-2019 diyAudio
