Shigaclone MKII Black - The builders Thread
Hi Tibi,
Thank you so much for taking the time for this. I guess I have been indeed confused with the different layouts and schematics. As I said, I was just trying to make sense of what I have here. I hate to use things that I don't understand how they work...
I was actually referring to both the first and the second version of your boards, but since I have only the 2012 schematics, that's what I was following, believing that it is the same for both.
Part of my confusion was also due to being under the impression that you were merely trying to reproduce, as faithfully as possible, the layout of the "original" board, hence the silly, I agree, zero ohm resistors question.
Again, I apologize for being a nuisance.
SL motor keeps turning
Hello.
I am building the Shiga CDT kit.
My status is.....
The control buttons & display LCD are not connected.
(Because I think that only 'Door'signal is necessary to read 'CD' information.
Except them(control buttons & display LCD), every parts are connected and soldered.
However, when I turn on,
the SL motor(Pin 3, 4 of J2 Mtor connector) keeps turning even after the pick up goes to the end position.
So I checked that P-SW pin(Pin 2)'s connection and it is good.
Can I get some advice here?
Thank you in advance.
Hello Danzup,
Here are some pictures. Hope they are detailed enough.
Robert
Robert,
You need to clean all the flux off for starters. The soldered joint adjacent to C42 doesn't look very good but hard to tell with all the flux. Also all the other new soldered joints made for the mods are very poor and don't look like the solder has melted and wetted the joint properly. Think you have an abundance of dry joints.
Aleks
Hello Tibi,
Did not dear to sink the entire board, but cleaned as well as possible using a brush dipped in the alcohol. Took the Tentlabs clock out and tried to solder it in the right possition. Than I realised that I'm not good in solderering (putting it mildly) and ruined the joint for the pin right under the T from Tentlabs. The solder doesn't connect anymore. Can I hardwire that pin to another point on the board?
Robert
