Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 7th November 2019, 10:34 AM   #1941
tvicol is offline tvicol  Europe
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
I see no reason why your Shiga is not working. Time to look at dac side.
Tibi
https://evotronix.eu
Old 7th November 2019, 11:26 AM   #1942
69mach1 is offline 69mach1  Netherlands
DAC is fine, tested with another cd player 2 days ago.
tested again today with that same cd player, no sound, wtf.
got a really cheap interlink, sound!!!
put the cheap interlink on the chiga, sound!!!!, heavenly music, YESSS.
With my expensive silver furutech interlink with wtb silver nextgen connectors, no sound.
The nexgen connectors were not playing ball and are very finnicky so it seems.
cleaned them, put them in the correct way and music again, that was the problem.
This is very embarrasing i must admit.
lesson learned, assumption is the mother of all f...ups
Thank you Tibi for the assist as always.
regards,
John
Old 10th November 2019, 09:53 AM   #1943
manamanam is offline manamanam  Greece
Default Weird noise from mechanism
Hi Tibi and other builders!
My Shiga black started to make a weird noise coming from the mechanism.
I have uploaded a sound sample of the noise when playing the first track of a disk.
There is a noise frequency pattern which is related to the speed of the disk.
This means that the frequency of the noise pattern decreases then moving to the last tracks.
I have changed the mechanism and nothing changed.
Any ideas?
Old 11th November 2019, 01:16 AM   #1944
sthcoaster is offline sthcoaster  United Kingdom
I think for many here it will be a case of "been there, done that" (or something similar)
Enjoy the feeling and enjoy the music
regards,
John
Old 11th November 2019, 01:25 AM   #1945
Meanwhile on the muppet show things go from bad to custard.
In my quest to get back to vanilla so I can eliminate any problems from basic I pulled all the mini regs etc. back in went L2, 3, 5, 9
have to dig through my stuff to see if I can find original crystal so I can remove Tentlabs to eliminate if there problems there (no scope)
for the moment when I power up I only get 2.2v at pin58
Old 11th November 2019, 08:04 AM   #1946
tvicol's Avatar
Any ideas?
You may try to replace optical ribbon cable, but I think this is a mechanical issue which may be related to the way you have implemented Shiga MKII, so I would like to see some pictures with entire assembly.
Tibi
Old 11th November 2019, 08:22 AM   #1947
tvicol's Avatar
Pin 58 LA9242 ? This is reference voltage and should be 2,5V.
Best regards,
Tibi
Old 13th November 2019, 10:35 AM   #1948
Yes that was the value I was working on
Got music playing today!!!
BUT not using the Sanyo "hens teeth" laser/mechanism
Only with the other non original laser/mech (vanilla, have not tried modded) - the ones you were sending out when the Sanyo was not available
Currently the Shiga does not like the Sanyo at all - either with vanilla laser or modded - both from yourself and both I have had working in my Shiga before all my problems
Do you think there is a difference in the laser height? Are the Sanyo more sensitive/less tolerant?
This is curious
Best regards,
Tibi
Old 19th January 2020, 04:44 PM   #1949
tvicol's Avatar
Some time ago I promised that freecad source Quantum files will be available to diyaudio users.
Anyone interested to build his own Quantum CD transport please leave his mail @ tiberiu_vicol [at] hotmail dot com and I'll share entire source files.
For thos interested to buy one I still have two Quantum CDT available for sale.
Tibi
So far I have shared via dropbox to 28 people. Only 6 have downloaded the zip file.
Please make sure that you look inside your spam folder.
Tibi
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 711 Today 11:37 AM
El Cheapo, builders thread tinitus Tubes / Valves 35 12th August 2019 01:20 AM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 10:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
