Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 8th August 2019, 11:36 AM   #1911
tvicol is offline tvicol  Europe
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
In other words.
Difference between Vin and Vout must be under 5Vdc in order for regulator to deliver 1A.
Tibi
https://evotronix.eu
Old 16th September 2019, 08:47 AM   #1912
sthcoaster is offline sthcoaster  United Kingdom
Just got around to fitting Zeno to my Shiga.
Sounds like a tigerrrrr!! 👍😀
Old 17th September 2019, 11:35 AM   #1913
Sounds like a tigerrrrr!! ����
Think my transformer is too powerful. Its a Hammond 183J10 10v secondary is rated 3A. I now reviewed the docs to find max is really up to 2A, closer to 1A preferable. Heat sink on regulator chip does get hot-ish. I have Zeno with Saligny. I will go back to using single winding on original transformer as per instructions.
If I add another Zeno powered from same winding (to power V1 for example) will that soak up more of the current?
Old 20th September 2019, 07:07 AM   #1914
Ok did a rewind and thought I'd nailed it but..
CD reads TOC and will play a chosen track BUT for only a couple of seconds before track stops and returns to TOC?
I've checked all my voltages and everything looks right to me. Have tried a couple of different mechanisms with the same result. Have swapped ribbon cables.
It's gotta be around that V1 where I have the LF50 (I have 100u on output as per instructions). Will try with different LF50.
Only have a DMM for testing. Tried to see if there was a V change anywhere at moment of stop
Pulling my hair out (what little of it I have)
Old 20th September 2019, 07:26 AM   #1915
tvicol's Avatar
I need some detailed pictures, to see what you have down and how you have implemented.
Tibi
Old 30th September 2019, 03:09 AM   #1916
tubo is offline tubo  Philippines
Hi Guys,
Im thinking of getting the tentlabs xo3 clock to upgrade, Im currently using the tentlabs xo. Has anyone used the xo3 or xo2 from tentlabs? How about the neutrino from new classd? Inputs will be greatly appreciated
Old 2nd October 2019, 03:47 PM   #1917
Hi guys,
Gas anyone tried upgraded xo other than the tent labs xo that had noticeable improvement?
Old 9th October 2019, 12:20 PM   #1918
tomaszf is offline tomaszf  Poland
Originally Posted by tubo View Post
Hi guys,
Hi Tubo
Try to use the neutrino clock, or neutron star.
You can find it here: NewClassD 16.9344 MHz Neutrino 2 Compact Audio Reference Clock
Old 10th October 2019, 12:05 AM   #1919
I remember one user commenting that once they had all high grade mods in place especially with Duelund at C11 and tentlabs xo further adding NewClassD clock didnít achieve further audible gain for them. So really upnto individual budget and preference
Myself I have Neutron Star and it is a nice piece of kit. NewClassD give excellent after sales service very friendly and helpful. If you keep an eye on PartsConnexion they often have NewClassD products at sale prices.
Hi guys,
Old 10th October 2019, 04:17 AM   #1920
Thank you guys for response.
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 693 9th November 2019 05:58 PM
El Cheapo, builders thread tinitus Tubes / Valves 35 12th August 2019 01:20 AM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 10:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
Copyright ©1999-2019 diyAudio
