Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Shigaclone MKII Black - The builders Thread Please consider donating to help us continue to serve you.
Old 8th May 2019, 07:48 AM   #1901
ofswitched is offline ofswitched  Taiwan
Banned
Originally Posted by tvicol View Post
I have decided to close Vicol Audio and focus on my job.
If any of you is interested in Shiga MKII please pm me and I'll do my best to serve you.
Tibi
Under the impact of streaming audio, Vicol Audio has been supporting for so many years, and finally closed...
Old 8th May 2019, 08:23 AM   #1902
sthcoaster is offline sthcoaster  United Kingdom
Tibi
Thank you for your your hard work developing your products and your good service to this community.
All the best
Clayton
Tibi
Old 8th May 2019, 08:30 AM   #1903
tvicol is offline tvicol  Europe
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Thank you, Clayton !
Vicol Audio was a hobby business. It never intended to compete with anything.
But, hey ! I'm still here to offer support, learn and develop new things for this great community.
Tibi
Old 15th May 2019, 03:10 AM   #1904
tomw is offline tomw  Australia
Default Please repost zeno drawing, thanks
For those who plan to use Zeno, here is a drawing.
Please note that output +8V must be connected with Sense as close as possible to Shiga MKII connector.
https://vicol-audio.com/img/zeno/ShigaMK2-Zeno.png
Tibi
Old 15th May 2019, 05:16 AM   #1905
tvicol's Avatar
Please take care that Zeno do not work without sense wire connected.
Sense wire must be connected at the load, as is clearly reflected in attached pictures.
Tibi
Old 15th May 2019, 05:31 AM   #1906
Thanks, tibi, makes sense.
tomw
Old 10th July 2019, 08:21 AM   #1907
tvicol's Avatar
This is to recall that Zeno is NOT a direct replacement power supply for Shiga MKII.
You need to take care on how to connect Zeno as per above drawings.
If you use Zeno with original Shiga MKII transformer, please use only one secondary. This way you have ~10Vac at Zeno input and power dissipated by regulator will be in normal limits.
If you use Zeno with Saligny, than you may use a trafo that deliver between 7Vac and 10Vac at 2A.
Tibi
https://evotronix.eu
Old 8th August 2019, 04:43 AM   #1908
Hi Tibi
Is there a manual for Zeno?
I am looking to make 26v - this is greater than the jumpers allow; I'm guess extra parts are needed?
Clayton
Tibi
Old 8th August 2019, 10:59 AM   #1909
tvicol's Avatar
Originally Posted by sthcoaster View Post
Hi Tibi
Clayton
Hi Clayton,
For 26V output you need to use R11 and R12 and no jumpers.
R12 = 10K
R11 = 174K
Please note that total power dissipated across regulator must be under 5W. For this use a transformer that have in secondary min 20Vac and max 22Vac.
Tibi
Old 8th August 2019, 11:32 AM   #1910
Thanks Tibi
Just to check that you refer to the voltage output (Vac) not the wattage (VA) that should be within those lower and upper limits? Sometimes I find transformer labelling confusing between the two.
I will check what I have before I proceed - I don't think I have anything at home between those values but might have a 20Vac there? Plan to try Zeno with TDA1541A Distinction V3 board.
Hi Clayton,
R12 = 10K
R11 = 174K
Tibi
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 726 27th January 2020 09:35 PM
El Cheapo, builders thread tinitus Tubes / Valves 35 12th August 2019 01:20 AM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 10:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
