Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 3rd September 2018, 04:14 PM   #1851
sigurd is offline sigurd  Belgium
Hi all,
My mods for the standard Black MKII :
C12 470 F Elna Silmic II
C43 220 F Elna Silmic II
V1 and V2 LM1086 - 5 volt + 100F output pins ( elna ) remove L2 and L4 (not L3 )
( ebay Littlediode )
output : series 0,33 F Black Gate NX and a good quality resistor ( 2 watt ) for R48
because input of DAC is a coil ( audio note )
This little modifications give a ( very ) big difference.
( little problem with the alu puck: must have more weight )
This CD transport sounds incredible good !!!! Stunning ! !!
Old 4th September 2018, 05:32 AM   #1852
tvicol is offline tvicol  Europe
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Thank you very much for your feedback, gentleman's !
Tibi
Vicol Audio
Old 5th September 2018, 12:57 AM   #1853
TIC37 is offline TIC37  Sweden
Default T-pad?
I have implemented all the tweaks mentioned in this thread except for the T-pad and I would very much like to try this also.
Though, I am not an electrical engineer but more of a monkey with a soldering iron so I need some help here.
I have understood that it should be doable with little effort but I need a guide! Anyone here who can describe the actions to take and requirements needed (is BNC cable mandatory for example)??
Carpe Diem
Old 8th September 2018, 04:12 PM   #1854
Default Dimkastas PSU
Building Dimkastas recommended PSU with LM117 or LM317 and I have a question.
I use this PSU instead of the original from Tibi and when I built it from the original schematic it was no problem getting it right on 8.15 Volt.
Dimkasta also tried the same approach feeding V1 and V2 which I want to copy. Instead of 3 green LED and a diode he surgested two green LED only for 5 Volt.
I come in at 5.266 Volt which is just a tad too high and I want to lower the voltage by at least 0.15 Volt. How to do this? I have green and red leds at home so if I get it right I should go for one green and one red LED instead if I have understood the schematics correctly, can anyone verify my thought?
Carpe Diem
Old 8th September 2018, 04:15 PM   #1855
Originally Posted by dimkasta View Post
Yesterday I switched to separate V1 and V2, using two LM117 tracking pre-reg + reg combos, like in the schematic I posted a while back. Just using only two red leds for the 5V reference, instead of 3 leds and 2 diodes for the 8V reference.
Nominal results are about 100dB of line rejection mostly coming from the tracking pre-reg, and separate load rejection from the second chip.
Cost including a heatsink that acts mostly as a chassis is around 10euros
Excellent results with big improvement in dynamics and microdetails.
This is the Schematics used!
Carpe Diem
Old 9th September 2018, 09:46 AM   #1856
And for the sharp eyed persons; you now notice that I am suffering slight disability to differentiate green and red so when I say green in most cases, this included, I mean red!
Carpe Diem
Old 11th September 2018, 10:46 PM   #1857
To answer my own question, I have now one red and one green LED and now I have 5.07 Volt which is more close to the target. Happy again!
Now it is just the question about T-pad that I would like some help with. Anyone here who would like to explain how to implement the T-pad or is it not possible to do?
Carpe Diem
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 623 5th October 2018 10:24 PM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
