Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 9th June 2018, 04:04 AM   #1831
nbivol is offline nbivol  Turkey
Originally Posted by tvicol View Post
Impresive work, Nicolae !
Hope sounds on pair with your orchestra.
Tibi
Thank you,Tibi
Old 20th June 2018, 09:19 AM   #1832
tvicol is offline tvicol  Europe
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
Shiga MKII price drop to 85 euro (standard version) until stock last.
vicol audio : Webshop
Tibi
Vicol Audio
Old 29th June 2018, 02:14 PM   #1833
gueri is offline gueri
I am going to make a new case for my Shiga MKII. I am very happy with it. It uses the SF-P101N-16 P modded mechanic. But I would like to know if the change of the C8 cap by a Mundorf EVO Silver-Gold OIL 450VDC 0.10F (I have one of this) would be a significant upgrade for my setup. I don't want to change anything. So if C8 upgrade only is a good point: perfect, else I leave as is.
Old 28th July 2018, 10:26 AM   #1834
lohk is offline lohk  Europe
lohk's Avatar
It may have been asked before here, but I did not find it:
How to convert or use the shigaclone 1 and 2 for I2S output?
/lohk/
Old 28th July 2018, 11:58 AM   #1835
tvicol's Avatar
Lohk,
LC78601 do not have i2s output. The single option is to use an s/pdif to i2s converter like WM8804.
On other hand I have seen bad i2s as well. Using i2s do not guaranty superior performance.
I personally use Shiga MKII high grade level3 with a Soekris r-2r dac trough s/pdif and it sound by far better than a MacBook Pro + Amanero via i2s to same Soekris dac.
Tibi
Vicol Audio
Old 28th July 2018, 06:37 PM   #1836
lohk's Avatar
Thanks, Tibi.
Fortunately my Soekris has recently arrived and will try this setup as soon as possible finally myself.
/lohk/
Old 5th August 2018, 09:02 AM   #1837
jbm95 is offline jbm95  Australia
After two years I've finally completed my build. While I've had it playing for nearly a year now, it's great to have the enclosure finished too. Thanks for your help in the beginning stages, Tibi.
Remote control is by an Apple remote with the IR signals decoded by an Arduino Nano. The Arduino outputs are linked to the button PCB through optocouplers.
Old 5th August 2018, 11:16 AM   #1838
comickitkit is offline comickitkit  Macao
Beautiful
If possible, can share photos for internal parts arrangement?
Old 5th August 2018, 12:22 PM   #1839
Thank you!
It turned out much tighter than I expected, especially around the display and buttons. The mech is held up by bolts through the base. You can just see the arduino under the mech, along with the perfboard I used for the additional circuitry.
I used my 3D printer to make mounting frames for each PCB, that were then glued to the aluminium. As for the aluminium, I had the front made by Front Panel Express, the lid done at my local laser cutting business, and the others cut by hand. The 3D printer also came in handy for the brackets to hold it all together.
Bonus out of focus image of my recently completed Bijou headphone amp. It's in an identically sized enclosure to the Shiga, so they look great side by side (if I say so myself).
IMG_20180805_200133.jpg IMG_20180805_200212.jpg IMG_20180805_200249.jpg IMG_20180805_200441.jpg
Old 5th August 2018, 01:50 PM   #1840
I can find you are using another clock placed under the CD turnable
Very Nice Work, The small chassis is what the reason I love 47labs product too
Thanks for your Sharing indeed
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 629 7th December 2018 02:24 AM
El Cheapo, builders thread tinitus Tubes / Valves 29 2nd December 2018 05:16 PM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 10:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
