Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 6th May 2018, 06:05 PM   #1821
tvicol is offline tvicol  Europe
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
If 1st solution do not work for you, I'll go for the second one. This mean you put L1 back and remake the trace you cut after AD151.
Tibi
Vicol Audio
Old 6th May 2018, 06:10 PM   #1822
TIC37 is offline TIC37  Sweden
Tibi
Either way if I use solution 2 or 3 I have to repair the trace that was cut, don't I? Could be a pain but what the h-ck, if I can repair the laser unit with single strands of copper cable then I should be able to fix this also. Thank you in advance, I'm already to it.
Carpe Diem
Old 6th May 2018, 08:34 PM   #1823
Default Done and working!
Away went the wire between U5 out and C11, in went L1 and repaired the cut trace, DONE!
I do understand you now Tibi, it sounds... well it is noticable, very noticable and damn good.
Thank you for all help, now I am going to enjoy music the rest of the evening.
Carpe Diem
Old 13th May 2018, 08:16 PM   #1824
vega65 is offline vega65  Norway
My Shiga is running with lc supplies
For 4 reflektor D , and for the original psu. Maybe I'll try the new Salas BIb for the 8 V later and another clock
Mechanics placed on a woodblock, would like to get some inputs on the best way to mount it.
And soundwise : Excellent!!!
Old 14th May 2018, 07:25 AM   #1825
tvicol's Avatar
I like your combo of transformers.
Many thanks for feedback !
Tibi
Vicol Audio
Old 17th May 2018, 05:00 AM   #1826
bbangkab is offline bbangkab  South Korea
Default Please check my board.
Hello.
I bought the kit several years ago.
I have not succeeded.
When I turn it on,
the CD spins and pick goes to start position.
and pick up lens moves up and down for some seconds.
However, it can not read TOC.
Could you check my boards, please?
Thank you in advance.
Click here to see pcb
Old 17th May 2018, 05:09 AM   #1827
Default Please check my pcb.
Hello all.
I bought this kit some years ago.
However, I have not succeeded to build it.
Actually, when I turn on,
the CD spins and laser pickup goes to start position.
Moreover, laser lens moves up and down for several seconds.
But, I can not read TOC at all.
Coul you check my pcb, please?
Click here to see my PCB
Thank you very much in advance.
Old 8th June 2018, 05:11 PM   #1828
nbivol is offline nbivol  Turkey
Default mission accomplished
Hello guys.Here's my version of Shiga MkII Black which I have finished today.
I used this case 田雨音響—CDM3、CDM4 轉盤機箱 that I brought from China where I was on a tour with my orchestra.
The case is spacious and solid with antishock table for cd mech,perfect for the full D-Reflektorized version.
Looks very good and sounds great.
Greetings
Old 8th June 2018, 05:42 PM   #1829
tvicol's Avatar
Originally Posted by bbangkab View Post
Hello all.
Hello bbangkab,
Pictures are very poor quality. It is hard for me to diagnose something when details are blurred.
Have you removed solder protection bulb from CD mechanic.
Have you mounted the mechanic on something ? It will not work as in picture.
Tibi
Vicol Audio
Old 8th June 2018, 05:47 PM   #1830
tvicol's Avatar
Impresive work, Nicolae !
Hope sounds on pair with your orchestra.
Tibi
Vicol Audio
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 629 7th December 2018 02:24 AM
El Cheapo, builders thread tinitus Tubes / Valves 29 2nd December 2018 05:16 PM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 10:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
