Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1811 |
Hi Steve,
I still need more info - some clear pictures - please. Regards, Tibi
https://evotronix.eu |
#1812 | |
![]() Quote:
L1 removed, Check! C11, still a mica 1nF, in place, Check! C68, 10uF tantalum, Check! C69, 1uF tantalum, Check! R65, 1kOhm vertical mounted resistor, Check! Cut the trace accordingly, Check! Output is nicely 2.52 volt, Check! But no TOC reading ![]() ![]() I start beliving that there is something in the description that is fishy cause according to your answer to Steve, above, U5 should be out over the C68 and then I think that I should be able to measure continuity between output and C68 but I don't.... nill, zip, zero, nada! Really don't know where to go from here, have checked, double checked and tripple checked all solder points and connections, both with magnifying glass and DMM. Just to verify the direction for the tantalums, plus is directed into center of the board for both C68 and C69?? It looks like a statement but it is a question. Traced the ground through C11, to C68 and C69 so plus for both tantalums should be in direction in towards center board. Sooo, what now??
Carpe Diem |
#1813 |
Hey TIC37, sorry to hear about trouble in paradise.
Despite my reporting success with thi mod earlier, I was premature (only read TOC the once and then nada- thought I must have dreamed it) and so I did end pulling the ADP - messed up the 2 devices I had and so are waiting for some more so I can have another go. I too got as far as having a strong steady 2.5v but not reading TOC like yourself. I started to think I had an error elsewhere. Anyway, I look forward to reading a solution here. |
#1814 | |
![]() Quote:
As I understand L1 is a ferrite bead filtering HF/RF and nothing more but when removing it I break the circuit if I don't replace with a 0 Ohm resistor or jumper. Sthcoaster reported that with L1 in place the unit read TOC but not without it, shouldn't L1 be replaced to maintain continuity?? I need help and quickly cause I am without nice playing music and I don't survive without my Shiga! ![]() Is there anyone who understand the function and implementation of the ADP151 that can help? I need a ![]() A schematic for the ADP151 implementation would help a lot!
Carpe Diem Last edited by TIC37; 5th May 2018 at 10:55 AM. Reason: Asked for schematics |
#1815 |
If you use a DMM to check, you will find one side of L1 is connected to R58 (0R) which is connected to pin 58 (VR) of the LA9294M. Therefore, when L1 is in place, it is using the chip's VR. Removing L1 is to decouple the reference from the rest of the circuit. That's my understanding of the L1 mod.
- Fred - |
#1816 | |
The laser unit is responding normally when I have no disc on the cd-player, laser head is moving up/down searching back and forward to localize TOC area. Laser is ok (verified by telephone) but as soon as a CD is present it can still not read. Where should I be able to measure the 2.5 volt that I get from ADP151 more than C11 positive side, it should be measurable somewhere else than there? I also need help to find plus respectively minus for the two caps C68 and C69, I have tried to follow ground plane to both of them but now I realize that I have 2.52 volt on the minus side of C69 while measuring 0 volt on the plus side and that I don't buy. Most likely one or both my caps have to do a 180 degree turn!
Carpe Diem Last edited by TIC37; 5th May 2018 at 08:24 PM. Reason: last question |
#1817 | |
C69 is on the input side (pin 1, there is a dot on the pcb) of the adp151. It should be around +5V, referenced to ground.
The output (pin 5) should be around +2.5, referenced to ground. Probably you forgot to add to the list of mods that you did, but I ask anyway. Did you connect a wire from output of the adp151 (should measure 2.5) to the +ve side of C11? See post. Quote:
I hope this will help to keep the spirit going before Tibi responds.
- Fred - |
#1818 | |
From your latest picture it seem that I have the plus and minus correct but how come that I have 2.5 volt on the negative side of C68?? That is buggering me. Still think that there is something fishy with the plus/minus.
Carpe Diem |
#1819 |
U5 function is to provide a very stable 2,5V reference.
The problem that I have observed later is that any difference between ADP151 output and LA9242M Vref pin 58 is translated in "error" voltage and unit will not read TOC. There are three solutions: 1st solution is to feed separately Vref only to PIN chip, which I already described by removing L1 2nd solution is to keep all parts in place. You mount everything and ADP will "force" output of LA9242M to remain stable at 2.5V 3rd solution is to remove only R58. This will isolate Vref from LA9242M from the rest circuit and will make use only of Vref provided by ADP151. Regards, Tibi
#1820 | |
![]() Quote:
Carpe Diem |
Thread | Thread Starter | Forum | Replies | Last Post |
F3 Builders Thread | Melon Head | Pass Labs | 693 | 9th November 2019 05:58 PM |
El Cheapo, builders thread | tinitus | Tubes / Valves | 35 | 12th August 2019 01:20 AM |
B1 builders thread | Bas Horneman | Pass Labs | 728 | 12th March 2018 07:45 PM |
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone | Tape Echo | Swap Meet | 3 | 10th August 2013 10:08 AM |
ezDAC v.1.5 Builders Thread | ezkcdude | Digital Line Level | 366 | 14th March 2013 04:31 PM |
New To Site? | Need Help? |
