Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
AD1862 PCB layout
AD1862 PCB layout
Old 27th August 2019, 05:17 PM   #121
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
AD1862 PCB layout
sorry you lost your gerbers.
any pictures of the finished design at least?
mlloyd1
Old 2nd September 2019, 10:17 AM   #122
Painkiller is offline Painkiller  Norway
Yes, it's pretty annoying to have lost all the files. Not really motivated to start from scratch again.
Here are a couple photos. One of the (dusty) unpopulated dac. And one of the populated prototype. It's really compact. I'm surprised at how good it sounds compared to how messy it looks
Old 17th November 2019, 09:26 PM   #123
...aaand here's the finished dac in its enclosure. All is diy except the I2SoverUSB receiver. Very happy with the result!!
I haven't heard many different dacs in my setup, but I can definitely say that it's way way better than the Chord Hugo 2 and the Naim DAC, both priced at $2000 USD. Would be interesting to compare it to some higher end dacs.
Old 18th November 2019, 09:55 PM   #124
pistollero is offline pistollero  Portugal
AD1862 PCB layout
Nice work. I saw on previous photos that you were using vishay var on riv. What is now your new resistor in use?
Old 19th November 2019, 12:45 PM   #125
Thanks!
I ended up with the Rhopoint 5G10 resistor. It's great. The value is 350R right now, because I have such efficient speakers and a high gain transistor amp.
General Resistance 5G10 Mini-Ohm Series | Rhopoint Components
Old 19th November 2019, 04:14 PM   #126
AD1862 PCB layout
Thanks!
Thanks for sharing, Painkiller,
Your work is great inspiration, i never heard ad1862.. i will try it for sure.
Old 21st November 2019, 12:38 PM   #127
diyiggy is offline diyiggy
Hello Painkiller,
Nice to hear from you. About R I/V, is there a big différence with the RhoRho 816G 1000R I sent you ;
I suceeded to put ufl- plugs on the previous design, you should keep the 3 x ground with the I2S inputs and also consider Sms full traces for 50 ohms matching.
Take me in for the new board please if you have my adresse yet...I push very far the passive composent tries.
If Smd Sussumu resistor is a good idea. You coule also draw the gerber traces with both the choice of througholes. 1/8 W size is the targett. Also same return about caps , consider please 0805 traces and throughole...will give you some components that do not exist on loser case size...here you should love to reach the Dave from Chord
"Leave the rocketships on ground" Brad Pitt (sorta from Ad Astra)
'".... and the planes as well" Childrens' copyright
AD1862 PCB layoutHide this!Advertise here!
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 10:01 PM
Yet Another Cmoy - PCB layout with Eagle and making PCB B&W_arthur Headphone Systems 48 12th November 2013 02:07 PM
pcb layout for- carlsburg Software Tools 20 17th June 2011 09:42 PM
pcb layout jamesrnz Power Supplies 0 9th March 2008 01:42 AM
About PCB layout gaetan8888 Solid State 14 11th January 2008 05:11 AM
Copyright ©1999-2019 diyAudio
