Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
My Kwack clock implementation
Thread Tools
Old 18th December 2003, 05:40 PM   #1
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Default My Kwack clock implementation
First of all I want to thank Elso for sharing his project.
Of course my implementation doesn't claim to be state of the art, since it's made on veroboard without a great experience on HF layout, but I thought it could be nice to share my building experience and to receive a feedback from who has built it (and from Elso, of course!).
I borrowed (again ) a digicam and took a few shots.
Pic 1: the assembly
Old 18th December 2003, 05:42 PM   #2
Andypairo's Avatar
2nd pic: a closeup of the board
As you can see I used a MAX913 as comparator and also a J310 instead of J309 as JFet.
The crystal comes from Elso so it can't be bad
Old 18th December 2003, 05:43 PM   #3
Andypairo's Avatar
Pic 3 output waveform
Not bad at all, considering that for now I only adjusted the duty cycle roughly
Old 18th December 2003, 05:45 PM   #4
Andypairo's Avatar
Pic 4: voltage at the gate of the JFET.. a good sinewave
Old 18th December 2003, 05:47 PM   #5
Andypairo's Avatar
Last pic.. voltage at source of Jfet.. can someone explain why the waveform has a bump?
Should I try swapping the fet with another model or I'd better change the value of the source resistor (or what else)?
Cheers
Andrea / waiting for comments
Old 18th December 2003, 06:41 PM   #6
Andypairo's Avatar
Default to bump or not to bump...
While taking further measurements to get rid of this bump I noticed the extreme sensitivity of the node connected to the source to capacitive loading to ground... I should have realized that before (the cap to gnd is only 39 pF !) but all became clear whan I left out the cap and connected my oscilloscope probe (10x)... I got a nearly perfect sinewave!
Then connected the same probe to the output and.. nothing! The oscillator had stopped working...
Conclusion: the bump is probably due to the capacitance of the probe
Cheers
Andrea / who enjoys learning from building circuits
Old 19th December 2003, 03:35 PM   #7
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Cool Kwak-clock
Hello Andrea,
You got decent squarewaves indicating a working clock. The "bumps" you mentioned are not important at all.
One of my first faults was connecting a 1x probe to a CMOS oscillator as it stopped working immediately. Yes ordinary probes have capacitance too.
I am using other kind of parts but I have seen pictures of the KC with all kinds of parts. Here is another one (not by me)
Old 19th December 2003, 03:51 PM   #8
zygibajt is offline zygibajt  Poland
I'm just finishing mine on vero board ,too.Had put it together week ago but waited for J309 to arrive (thanks Elso for J309,i just recived it a couple of hours ago).
I'm just not qiute sure how the pin-out of J309 is and how to put it into circuit.
I assume drain goes to + supply,source to crystal and gate to AD8651 and to ground trought 1Kohm resistor.
Is it correct??
Bartek
Old 19th December 2003, 04:04 PM   #9
Banned
Lightbulb Pinout
Is it correct??
Bartek
Hello Bartek,
See this site for pinouts by Yeo :http://www.diyparadise.com/clock.html
It is Drain to supply, Source to 1k and Gate to crystal.
Old 19th December 2003, 04:08 PM   #10
Thanks a lot.
Maybe i will put some photos tomorrow if I get the camera.
For now I will use it with CDP supply but will build separate this coming week.
Bartek
My Kwack clock implementationHide this!Advertise here!
Possible PCM2706 implementation jaycee Digital Source 9 5th November 2006 11:14 PM
My implementation of the Audidigit T-amp Mick_F Class D 9 3rd October 2005 08:50 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
My Kwak clock implementation. Bernhard Digital Source 2 24th May 2004 09:51 PM
Kwack or another clock on pc souncard Ryssen Digital Source 0 27th January 2004 10:44 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
