Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony CDP790 and KSS240 Restoration Project
Thread Tools
Old 3rd January 2021, 04:51 PM   #221
maouna is offline maouna  Greece
The laser unit i received from ebay didnt work.It was rusty and oxidized.thankfully i got a refund.I was pointing the phones camera on the laser and no light would come out.So i unsoldered the small ribbon that goes to the PD,LD and tested both of the diodes with the diode tester.they seemed ok but no light coming out of the laser (iam looking with my phones camera)so i made a small current source around 35ma as the one on the schematic of kss240 and tested again.no light out of the laser diode.I was wondering whether it is easy to replace the diode itself and get it working as there are quite cheep at alliexpress.the old diode came out pretty easily as it was glued.
I found some potential replacements.
RLD78MRA1
QL78D6S
SLD105VL
RLD78MD-K
RLD78MRA1 pdf, RLD78MRA1 description, RLD78MRA1 datasheets, RLD78MRA1 view ::: ALLDATASHEET :::
QL78D6S-A datasheet
HTTP 301 This page has been moved
https://www.google.com/url?sa=t&rct=...6z8n0pYKh2UdW_
Old 3rd January 2021, 05:23 PM   #222
Mooly's Avatar
A diode tester probably wouldn't be any use on a laser diode because the current needed for lasing to start is probably much higher than the test current. There is also the real risk of damaging the LD due to transient spikes which happens in nano seconds and can damage the facets of the diode chip.
The diodes do come out of most pickups very easily but whether a replacement will work without the internal optics being aligned to it is another matter.
There is a thread here which is long and spans a few years:
Dead Laser Pickups - why not replacing the Diode only?
  Reply to this post
Sony CDP790 and KSS240 Restoration ProjectHide this!Advertise here!
Thread Tools
Someone Has Themselves a Challenging Speaker Restoration Project! DreadPirate Multi-Way 1 12th July 2010 06:25 PM
Old Tube Radio - Restoration Project Algar_emi Tubes / Valves 21 5th June 2008 12:53 AM
Thorens Prestige restoration project user510 Analogue Source 2 4th December 2004 12:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
