Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Thread Tools |
#211 |
Could be a bargain for $10, particularly if it has a good RAFOC (laser assembly)
![]() Enjoy ![]()
Installing and using LTspice IV. From beginner to advanced. |
#212 |
Can those cheap chinese oscilloscopes be used to show the eye pattern of a cdplayer and to calibrate it succesfully?
Hantek dso5102p usb digital storage oscilloscope 2channels 100mhz 1gsa/s Sale - Banggood.com Hantek dso2d15 dual-channel + afg digital storage oscilloscope 150mhz 1gsa/s signal generator oscilloscope 2 in 1 Sale - Banggood.com |
#213 |
No idea tbh as I've never used one. The bandwidth is more than adequate but how a complex eye pattern would look I wouldn't like to say.
I imagine you would see some sampling artefacts and so it would look less clean than viewing on an analogue scope, but that it should be representative in amplitude given the bandwidth.
#214 |
i was thinking of buying one of these but i cant find a video anywhere showing the eye pattern on such cheap oscilloscopes.I dont know whether they have this chop/alternative mode or not.
#215 | |
Good quality, i'm afraid not. ![]() |
#216 |
Chop and Alternate is used when using a scope in dual trace mode. Viewing the eye pattern is done with a single trace so those don't really figure into things.
#217 | |
#218 |
Well you would normally turn the second channel on the scope off (so it behaves as a single beam) and then the Chop/Alt don't apply. The eye pattern is a single measurement that can be done on a single beam scope.
------------------------------------ The difference if you have both traces running is that Alternate traces out first channel 1 and then channel 2 and so on. Chop displays both together with the traces literally 'chopped' as they scan left to right. It makes a difference at really low sweep speeds where you want to see both traces together and not have one trace disappear while the other traces out. Found this: #31: Analog oscilloscope ALT, CHOP, ADD, INVERT vertical controls - YouTube That's all it does ![]()
#219 |
Today i received the kss240a i ordered 1 month ago for my denon-dcd625.The original kss240a loooks like the one below on the left but what i received had a 10pin ic instead of a 24pin and another extra ic that the original doesnt have.( picture on the right).When i bought it from the seller ,the photo corresponding to the item was that of the one with 24pins and so i decided to buy it but i received one with 10pin ic.
Is this of inferior quality? |
#220 |
As far as I know none of the replacements are genuine Sony parts and haven't been for nearly 20 years now.
All you can do is fit it and see how it performs. Its a totally different design electrically but as long as it works to the original spec then it should be OK. Another difference you will notice is that original parts have the sintered phosphor bronze bearing shells whereas the replacements use moulded plastic.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Someone Has Themselves a Challenging Speaker Restoration Project! | DreadPirate | Multi-Way | 1 | 12th July 2010 06:25 PM |
Old Tube Radio - Restoration Project | Algar_emi | Tubes / Valves | 21 | 5th June 2008 12:53 AM |
Thorens Prestige restoration project | user510 | Analogue Source | 2 | 4th December 2004 12:07 PM |
New To Site? | Need Help? |
