Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac I/V convertion with very low distortion
Old 22nd April 2019, 11:37 AM   #961
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
What is the best PNP complement to the ZTX1051a ?
Old 22nd April 2019, 03:28 PM   #962
kimschips is online now kimschips  Denmark
Originally Posted by smms73 View Post
The calculated input noise with 5 ohms input is 0.36nV/Vhz
The gain at 1kHz is 68db but can be adjust changing R6 value.
The distortion is with a 1mV 1KHz input signal ( 2.5 V output )
Nice circuit have you listenet to the circuit?
What about adding a diamond buffer to the output?
Best regards
Old 22nd April 2019, 03:42 PM   #963
dreamth is offline dreamth  Romania
I have no idea, i have only ztx 1051, 1055 and 1149(pnp)...I found them thrown out in a bin at a factory i worked in the past at.They were doing lots of very high voltage power supply so they must have used these transistors as drivers in some old products along with the classical 651, 751, 851, 951...
Old 22nd April 2019, 05:18 PM   #964
as_audio is offline as_audio
This week I've been thinking about alternatives to my I / V converter, because since I'm going to use 8 channels and balanced connections to the amplifier, that means I'll have to use 16 of these circuits.
A very interesting alternative is to use Jan Didden IV converter with a small change. just added a current source to increase the gain, the results are promising.
Post 948 :
On Q4 you would want to add a connection between collector and base.
"Jan Didden IV converter" - where can it be seen ?
Old 22nd April 2019, 05:21 PM   #965
smms73 is offline smms73  Europe
Simple, high-quality I/V converter | Linear Audio NL
Old 22nd April 2019, 05:23 PM   #966
Best regards
I have made the schematic just this morning based on a suggestion from Joachim Gerhard. Only tested in spice
dac I/V convertion with very low distortionHide this!Advertise here!
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
IRF610 I/V convertion from Pass Labs D1 dac - single ended schiller Digital Line Level 5 15th October 2009 04:33 PM
Distortion+low volume.. GeirW Tubes / Valves 5 25th November 2004 12:04 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2019 diyAudio
