Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#491 | |
See where it says "X1" near the corner of the oscillator, it is printed on the PCB. That corner should be it. See "Red" below. The "Green" is your Ground.
"Elsinore Project" DIY Speaker System - "Don't take anything I say as an affirmation, but as a question." Niels Bohr [i.e. be humble] |
#492 |
Thank your of your suggestion. Have you worked on this machine before? Is it that this design doesn't have the caps to remove?
Please excuse my skepticism. It is curious to me that the manufacturer of the replacement clock would put a diagram on his site-- as a part of the instructions how to install his clock-- that the two caps coming out of the original clock have to be removed. Please advise. Thanks. |
#493 | |
There are no caps to remove in your case. What you are removing is a powered oscillator (it should be 3.3V) and not a crystal, which is basically as resonator that needs those caps. The new clock is also a powered oscillator (it should also have its own 3.3V). So in a sense you are replacing like for like. Probably done a thousand of clocks by now. If Coris is around (he is likely sleeping now), he will tell you the same thing.
#494 |
Thanks again for the clarification. In terms of the power supply for the new clock, it says that it needs 12v going in but the clock runs on 3v. Does that mean that I have to find a 12v source for it in the player and then before it gets to the clock, it steps it down to run the clock 3v? Or do I find 3v in the player and use that directly? I have attached the instructions from the manufacturer's site. Thanks for you help so far.
#495 |
p.s. I am going to assume that it is 12vdc. Correct me if I am wrong.
#496 |
Never mind. I figured out. It works. Thanks for your help.
#497 |
Please advise.
I have an Oppo 103 Audiocom Signature. I have a desire to add performance. Where can I buy OCXO TCXO clock module for CPU and HDMI? |
#498 |
Hello everyone, I had a problem with the oppo 95 pcb, could someone tell me where to buy a replacement pcb thank you?
#499 |
I think it is very difficult or possible finding a PCB replacement, unless one might buy (find) a whole 95 player (if available). Could you elaborate what about your problem?
#500 |
Correction to above post: "I think it is very difficult or impossible finding..."
Thread | Thread Starter | Forum | Replies | Last Post |
New Oppo BDP-93/95 and DIY possibilities... | Joe Rasmussen | Digital Line Level | 2 | 2nd June 2011 04:00 PM |
Anybody did compared the Pioneer Elite BDP-09FD and the Oppo BDP-83 ? | gaetan8888 | Everything Else | 0 | 5th April 2010 07:16 PM |
Oppo BDP 83, and Tube amps | ronton3 | Digital Source | 2 | 8th March 2010 11:31 PM |
SONY BDP-BX2 doesn't power on | yzriver | Digital Source | 1 | 24th February 2010 09:19 AM |
Newest OppoDigital.com BDP-80 - opinion | FastEddy | Digital Source | 1 | 20th February 2010 02:09 PM |
New To Site? | Need Help? |
