Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open-source USB interface: Audio Widget
Thread Tools
Old 7th November 2020, 09:02 AM   #2431
borges is offline borges  Norway
Wow, that's a pretty hefty mod!
Could you send the exact part names of the capacitors you use? And please also the capacitors you discard.
It would be very interesting to plug them into my test rig (vector network analyzer) and see if there is a correlation between how they measure and how you say they sound.
Thanks,
BÝrge
Old 7th November 2020, 01:34 PM   #2432
Sagen is offline Sagen  Norway
Hi , tanks for interest. I have discardet ( snaped ) all the big blue 10nf.
Desolder the 470ohm resistors after DAC chip, snapped of the two 2n2 to ground before RCA. Snaped of the 10nf after C15 ( C26 ). And solder 0.5mm silver cable from first point after DAC to RCA.
So the caps: C21/C31 is Elna Cerafine 470uf 25V.
C15 is Nichicon KZ ( MUSE ) 1000uf 25V.
All the rest of the oem 570uf OS-CONs are changes to Elna Silmic II 470uf 6.3V.
Frank
Old 9th November 2020, 10:08 AM   #2433
Thanks! Looking forward to evaluating the caps with instruments.
BÝrge
Old 5th March 2021, 04:45 PM   #2434
4545 is offline 4545
Frank
I have done it. Thank you. Magnificent. Now I have to get new underwear after finishing it.
Old 10th April 2021, 07:38 AM   #2435
Hi, 4545
Great job, and very fun!! How do you like it?
It maby a rollercoster soundwise, one day no bass, one day to hard in top.
But just wait it will be fine, 100-200 hours before its stabil.
  Reply to this post
Open-source USB interface: Audio WidgetHide this!Advertise here!
Thread Tools
Async 192Khz USB - the SDR-Widget collaborative project SunRa PC Based 5 26th April 2011 06:38 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
