Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Micro DIR9001 + PCM1794A DAC
Old 8th December 2008, 01:33 PM   #31
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I need a clock smaller than the normal half-size DIP. This is only 7mm x 5mm so I was hoping it would be good enough. Are you saying I shouldn't bother with it?
EDIT: I could go with this one if it is any better.....
http://www.crystekcrystals.com/cryst...lock/C33xx.pdf
Old 8th December 2008, 06:51 PM   #32
mako1138 is offline mako1138  United States
Yeah, that one's probably better.
Old 12th December 2008, 04:41 PM   #33
Finished etching the PCB. My mouser order with the XOs wil be here tomorrow, so hopefully I can get it built and working then. Still haven't found the time to make the I/V layout, but I should probably get this working first anyway.
Got my decent camera back as well.
Old 12th December 2008, 05:40 PM   #34
DVBjunky is offline DVBjunky  Germany
Nice. Soooo smalll..........cutie MicroDAC!
Old 12th December 2008, 10:22 PM   #35
JC951t is offline JC951t  Taiwan
Wow, the work of an artist.
Very very nice.
Old 13th December 2008, 12:12 AM   #36
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
An artist would never make something so functional! Looks more like the work of an engineer to me
Brian
Old 13th December 2008, 12:16 AM   #37
Whichever way, it has to come from the soul.
Old 13th December 2008, 12:47 AM   #38
I'm neither an artist nor an engineer; I'm just a Janitor with an expensive hobby. Sorry to disappoint.
Old 13th December 2008, 05:41 AM   #39
Janitor ? Hmmm if that's what it takes to be that
good at diy audio, I'll take up a job as a janitor
too. Ha3
Old 13th December 2008, 08:38 PM   #40
Default Finished......
.....and it works!
I thought my noob luck had run out at first because the output was incredibly low. I forgot I left the passive I/V resistors off this board because I plan to use an active stage.
Mouser somehow put 47k resistors in a bag that was supposed to have 10nF caps, so I had to salvage one off a dead class-d amp.
Micro DIR9001 + PCM1794A DACHide this!Advertise here!
Micro Jacks and Micro Pins for board-board connection jazzist Parts 2 25th July 2016 07:04 PM
FS: 25pcs each PCM1794A and DIR9001 theAnonymous1 Swap Meet 1 5th December 2009 02:11 PM
Dir9001 rehanabid Digital Source 0 26th January 2007 09:43 AM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 05:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
