Building the ultimate NOS DAC using TDA1541A
Old 5th November 2018, 03:16 PM   #6751
3lite is offline 3lite  Poland
It is, it will require some work in general, but it is doable. You need transimpedance amplifier with high amplification though. That is in order to see LSB change.
Personally I would just do an FFT toggling LSB and below LSB.
Old 6th November 2018, 10:18 AM   #6752
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Guys,
Is this the right thread to discuss Ian's invention?
Doesn't it deserve its own thread???
M.
Old 6th November 2018, 12:05 PM   #6753
batteryman is online now batteryman  United Kingdom
Originally Posted by maxlorenz View Post
Guys,
M.
We should probably move the discussion of Ian's boards to this thread as this one is really for ECD Designs.
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 6th November 2018, 08:17 PM   #6754
Hanze Khronye is offline Hanze Khronye  Australia
Guys,
M.
As the only available I2S to PCM plug and play module, discussion with regard to suitability for specific use with tda1541A seems perfectly at home in 'ultimate tda1541A' thread ?.
Old 6th November 2018, 08:27 PM   #6755
weissi is offline weissi  Austria
Well, I don't want to repeat myself, but there is the module from JLsounds that supports direct USB2PCM for the TDA1541A....
regards / servus
Old 7th November 2018, 01:58 AM   #6756
Talkaing about I2S to PCM, and not USB to PCM.
Old 9th November 2018, 06:51 AM   #6757
JOSI1 is offline JOSI1  Germany
Mosaic-DAC
Hi John,
will there be a new revision of the Mosaic-DAC.
What is the present status.
Old 10th November 2018, 12:14 PM   #6758
ecdesigns is offline ecdesigns  Netherlands
Hi JOSI,
Mosaic-DAC
Hi John,
Yes, we completed the new MOS16 and MOS24 DACs that will be presented on our new website soon, together with some other very interesting new products. So keep an eye on our website.
I attached some photographs of the first completed MOS16. The USB socket on the rear is for internal battery charging only.
The MOS DACs can also be connected to USB audio sources while retaining required advantages of Toslink. We designed the UTOS for that, third picture shows the first UTOS prototype.
Old 10th November 2018, 03:31 PM   #6759
lcsaszar is offline lcsaszar  Hungary
Alternatively, my DAC linearity test CD that I mentioned several post ago could be used. It toggles LSB at each bits on three DC levels (bit n-LSB, bit n, bit n+LSB). If LSB is missing, you will see only two DC levels.
Old 10th November 2018, 03:41 PM   #6760
Thanks, that's a better idea.
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
Copyright ©1999-2019 diyAudio
