Optical or Coax Input to DAC
Thread Tools
Old 3rd April 2021, 09:00 PM   #11
TNT is offline TNT  Sweden
Originally Posted by canvas View Post
The problem with Toslink is usually the transmit/receiver module. They induce too much jitter.
Sorry that you have a jitter sensitive DAC - try another receiver circuit and enjoy the benefit of opto isolation!?
More distortion to the people! Timing . . . . is paramount.
Old 3rd April 2021, 10:00 PM   #12
laserscrape is offline laserscrape  Ireland
What do you think of andrea's solution for the I2S input on upcoming FIFO (input I2S isolator > LVDS over HDMI > output I2s isolator) in terms of isolation, good as opto?
The CMR of LVDS would make it more resilient to external RFI pickup I guess, maybe not quite opto level. Not sure about the isolation level of opto compared to some of the other digital isolator types.
Old 3rd April 2021, 11:00 PM   #13
I use opto to distance any offending radiator by a meter rather than centimetres...
Old 4th April 2021, 01:01 AM   #14
totally analogue is offline totally analogue  New Zealand
totally analogue's Avatar
Recalling digital theory the optical fibre will introduce more jitter but any DAC worth it's salt will have re-clocker on the input so try both. Out of interest I tried the coax and optical feeds from my disc player into my Dac/amp. The optical sounded marginally cleaner but neither came close the analogue feed ;-)
Old 4th April 2021, 01:06 AM   #15
diyiggy is online now diyiggy
diyiggy's Avatar
Me readings you results in a nervous breakdown and I'm bringing back my Rega Planar 3 before my pills !
Pi VII au bord du P.
Old 6th April 2021, 03:27 PM   #16
Cney is online now Cney
I think you are confused with noise. Toslink has 2 extra conversions going on which induces noise. Distance wise it reigns supreme yes.
If not is than BNC would be my choice. And I think many DAC manufacturers would agree. I know of a couple that prefer BNC over Toslink.
Old 8th April 2021, 05:03 AM   #17
raptorlightning is offline raptorlightning  United States
raptorlightning's Avatar
If you buffer and retransmit the signal (usually inside the DAC, if not with a little external hardware), then the source noise means nothing as long as you don't drop a bit due to extreme jitter/poor interconnects.
Reclocking in or at the DAC IC achieves this and so do SPDIF receivers like the WM8804 - FIFO buffers so the input and output clocks are as isolated as they can be.
  Reply to this post
Optical or Coax Input to DACHide this!Advertise here!
Thread Tools
FS: Stereo USB DAC Amanero Combo384 + DAM1021, Optical, Coax, VU Meter benproiii Swap Meet 6 2nd September 2017 07:55 PM
If you use the SPDIF/coax output of your DAC, and plug into the SPDIF/coax input of ag8908 Digital Line Level 6 27th March 2014 11:11 PM
HiFimeDIY 9023 + CS8416 COAX and OPTICAL input azimut Digital Line Level 4 10th February 2013 09:31 PM
115 V wiring for Hifimediy Sabre Coax/Optical DAC ES9023 +CS8416 192k/24 AngleCard48 Construction Tips 2 26th December 2012 01:34 PM
DIY Dolby decoders (with optical and coax inputs) Jeeves_Moseley Digital Source 1 1st November 2001 12:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
