i/v stage problem
i/v stage problem
Thread Tools
Old 14th March 2021, 01:12 PM   #1
maxpou is offline maxpou  Canada
maxpou's Avatar
Default i/v stage problem
i built this stage iv for the PCM1798 or COD from twisted pear audio, but i don't understand why i have dc offset at the output ( 0.7V) while my j-fets are match paired. I have this problem when I put a cap in C7 and C8.
Someone can help me?
Thank you! Maxpou
Old 14th March 2021, 01:26 PM   #2
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
So, when C7 and C8 are removed there is no D.C. offset?
If yes, then measure the D.C. voltage at the drain of Q4 and the gate of Q5, with C7 and C8 in place, to see if they are symmetrical with respect to ground. If there's an imbalance, my first guess is that one of those 1,000uF e-lytic caps may be leaking D.C. Obviously, the offset should not be affected by C7/C8 which should function as open circuits at D.C.
Old 14th March 2021, 01:45 PM   #3
Lampie519 is offline Lampie519  Netherlands
Lampie519's Avatar
Maybe the FET's are matched but not your resistors (4.7 Ohm). Only a slight mismatch could give this DC offset.
Old 14th March 2021, 01:49 PM   #4
maxpou's Avatar
Hi Ken,
thank's for reply. my first test was to change the capacitors for 100uF, without success, 2nd I lowered the resistors R8 and R9 by half, without success and my last test was to change my j-fets without success too.
Maxpou
Old 14th March 2021, 01:53 PM   #5
maxpou's Avatar
Hi Lampie,
i use the prp resistor 1% and i verified each of them.
Maxpou
Old 14th March 2021, 01:55 PM   #6
Ken Newton's Avatar
Originally Posted by maxpou View Post
Hi Ken,
Maxpou
1) Just to confirm, there is no D.C. offset with C7/C8 removed?
2) Also, what are the supply voltage readings at the drain of Q4 and the gate of Q5 with and without C7/C8?
Old 14th March 2021, 01:56 PM   #7
lcsaszar is offline lcsaszar  Hungary
R7 does not have any effect at all?
Old 14th March 2021, 03:03 PM   #8
maxpou's Avatar
Hi Ken,
no d.c. offset without C7/C8 and i have 10.15V in drain of Q4 and 10.26V in gate of Q5.
Thank's Maxpou
Old 14th March 2021, 03:05 PM   #9
maxpou's Avatar
no because i have a coupling cap C2.
Maxpou
Old 14th March 2021, 03:27 PM   #10
Lampie519's Avatar
Try to put a potmeter of 100 ohm with 10 ohm in series over R6 and check if you can adjust to 0v on the output.
i/v stage problemHide this!Advertise here!
Thread Tools
Very Strange Problem with DIY Phono Stage (Possible Load Problem?) steve516 Analogue Source 9 26th February 2014 08:06 AM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
