HDMI to I2S  (for audio not transport) working but w/ noise.
Thread Tools
Old 26th February 2021, 05:26 PM   #11
rfbrw is offline rfbrw
Originally Posted by mga2009 View Post
Thanks for your reply.
Is there a way to fix this? Software or hardware wise?
Are you able to measure the MCLK frequency of the HDMI board? It is possible to run the ADAU1701 off it.
Old 26th February 2021, 05:28 PM   #12
mga2009 is offline mga2009
If I need an oscilloscope, then I am out of luck as i don't have one.
If there is another way, I can try it.
Old 26th February 2021, 05:36 PM   #13
Markw4 is offline Markw4  United States
You really should have an oscilloscope if you are doing the kind of stuff we are talking about now. It will make your life much easier. Just as essential as a DVM for electronics work.
Old 26th February 2021, 06:00 PM   #14
Yes yes, I know...
It's definitely in my "to buy list"
Old 26th February 2021, 06:51 PM   #15
I suppose you could remove the crystal from the ADAU1701 board and use MCLK from the HDMI board instead. Default HDMI board MCLK maybe 256Fs and if that fails setup for 384Fs. The PLL mode pins only give 4 options and there is every chance the HDMI board MCLK frequency is within that range of 64Fs to 512Fs.
  Reply to this post
HDMI to I2S  (for audio not transport) working but w/ noise.Hide this!Advertise here!
Thread Tools
DIY I2S IIS over HDMI output to SMSL M500 USB DAC (USB -> I2S with MQA) cartman Digital Source 11 16th January 2021 02:11 PM
A simple cable to connect I2S over HDMI => I2S over RJ45 devices phile1 Digital Line Level 36 9th July 2020 01:08 AM
HDMI i2S output from SATA to i2S board ozcal Musicaltech 0 24th September 2015 06:56 AM
Laptop HDMI Output and DAC HDMI I2S Input. Can I get this going? mikone Digital Source 1 7th September 2010 11:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
