Analog Delta-Sigma interpolation DAC
Thread Tools
Old 18th February 2021, 08:35 PM   #301
U130421 is offline U130421  Antarctica
Originally Posted by MarcelvdG View Post
Isn't that a standard two times interpolating filter, that is, a combination of inserting zeros and brick-wall low-pass filtering? Instead of a windowed sinc, you can also use the Parks-McClellan program (based on the Remez exchange algorithm) to find a finite impulse response that approximates the ideal sinc.
No zero stuffing. Instead of sinc interpolation of very high samples, it is Hamming windowed.
All I find from Park McClellan is FIR filter design, any reference for the sinc?
Old 18th February 2021, 08:44 PM   #302
Hans Polak is offline Hans Polak  Netherlands
Sorry Hayk, it is for 100% zero stuffing with one zero.
No question about that, believe me.
Exactly what I did with 3 zero’s.
Hans
P.s. with such a short filter you will get miserable results.
Old 18th February 2021, 08:51 PM   #303
Another one with Kaiser window.
Windowed Sinc Interpolation | Physical Audio Signal Processing
Old 18th February 2021, 10:10 PM   #304
MarcelvdG is offline MarcelvdG  Netherlands
I think you are both right, actually.
The filter from post #301 could be one of the two polyphase decompositions of a two times interpolating 32-tap FIR filter (two times oversampling filter), the other polyphase decomposition is then a group of zeros, a one and another group of zeros.
Real interpolating filters are never made of an oversampler that inserts zeros and then a low-pass filter. In practice these two steps are intertwined because it is more computationally efficient.
If you would first insert zeros and then pass it though a normal filter, for each output sample, half the filter coefficients would be multiplied by zero. You can save half the multiplications by leaving out those coefficients. You then end up with a filter of half the length that uses two different coefficient sets for the odd and even output samples, so in fact it becomes a time variant filter. For some reason those coefficient (sub-)sets are know as polyphase decompositions.
In this specific case, one of the two polyphase decompositions has only one one and a bunch of zeros as its coefficients, so you can actually time multiplex between a delayed version of the input signal and the output signal of the filter of post #301. That way you need only a quarter of the multiplications.
Old 18th February 2021, 10:40 PM   #305
Regarding Parks-McClellan, all design methods for linear-phase FIR low-pass filters lead to some finite-length approximation of a sinc. The Parks-McClellan approximation leads to an equiripple frequency response in the pass and the stop band.
As an example, attached is the impulse response of a 128-tap Parks-McClellan filter with a pass band up to 0.22675 fs, stop band from 0.27325 fs onwards, 12778 times as large error in the pass band as in the stop band. The picture with the discrete points is the correct plot, the other one has nonexistent line segments added for clarity.
Old 19th February 2021, 06:08 AM   #306
Maybe they used a standard two times oversampling digital filter for the circuit of post #258 and sent the odd words to one DAC and the even words to the other DAC, with 1/88200 s delay between them. Or they just made a half cycle delay filter like the one from post #301 to feed one of the DACs, still with 1/88200 s shift between the DACs. That way they can have a good suppression of the first two images and still claim it is a non-oversampling DAC without steep analogue filter.
Old 19th February 2021, 08:55 AM   #307
There are all kind of tricks to reduce the amount of multiplications when calculation resources are restricted, but at the end if more samples come out then came in, it boils mostly down to be a smart derivative of zero stuffing and straight convolution, tricks that may or may not result in a loss of sound quality.
So when enough processing power available, why bother ?
Over the last years since processing power is abundant, even music programmes like JRiver can do the convolution whith your self fabricated Fir filter coefficients.
With a 1000 point Fir and 4 times upsampling, 44e6 multiplications have to be done per second, which even a fast Intel processor can achieve.
A graphic NVidia card can do at least 100 times more than that.
There is a clear development with DACís having all sorts of different filters, and DSPís or FGPAís can do the job with ease.
So I think the challenge is nowadays not to have the smartest algorithm but to have the best sounding filter that can beat the supposed clarity of NOS.
Hans
P.s. I have never read a test in Stereophile of a NOS Dac that beats all the oversamplers, so what to think of that ??
Old 19th February 2021, 10:10 AM   #308
I simulated the Accuphase solution and added 8 time shifted samples of a NOS Dac.
All the supersonic images are still there, but as can be seen, compared to the Sinc of a single sample NOS Dac in Red, these images are suppressed quite a bit depending on their frequency, so it is effectively in some way.
But an analogue filter will still be needed to correct the loss of level at the high end side of the audio range, caused by the Sinc.
Hans
Old 19th February 2021, 10:36 AM   #309
It seems unlikely to me that adding a bunch of zeros is going to improve the sound quality.
Actually 176.4 million multiplications per second are needed when you don't use polyphase decompositions: 1000 times 4 times 44.1 kHz. Of those 176.4 million multiplications, 132.2 million will be multiplications with the stuffed zeros.
Old 19th February 2021, 12:24 PM   #310
Marcel,
Right, adding zeroís donít improve things, but it helps to understand the process, because thatís basically whatís it all about.
The execution how to do it is up to the designer and as long as no shortcuts are taken that are harmful, thatís o.k.
The solution with two Dacís and only oddís in between being processed is absolutely better as adding two time shifted samples, but it doesnít seem the best way to follow because the whole chain from beginning to end differs from the even channel adding extra noise.
We agree on the calculations: 176M-132M are exactly the 44Mflops that I mentioned.
Hans
Analog Delta-Sigma interpolation DACHide this!Advertise here!
Thread Tools
Philips tda1305 (hybrid multi-bit/bitstream DAC with interpolation) 1z2a3y Digital Line Level 37 22nd January 2021 12:02 AM
High quality parts used delta-sigma dac vs cheap parts used r2r ladder dac Esotar01 Digital Line Level 2 6th May 2016 12:50 AM
Question about DAC interpolation cuallito Digital Line Level 1 28th April 2011 11:11 PM
Delta-current linear-interpolation DAC wimms Digital Source 86 4th November 2004 02:05 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
