Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
Hey there,
(I'm from France, sorry if I make English mistakes ![]() I'm trying to do this DIY project but I'm not very familiar with some of the part's i'm using. I did not find anyone that has tried this specific setup before. Here is the idea : I want to use the Arylic Up2Stream Pro v3 as my main source for powered speakers to make them wireless. I'm going to make a pair of them, with an active crossover. (I want to use 1*up2stream and 1*Piano in each speaker, as the two Up2Streams can become a stereo pair) 1: Is it actually possible to use the Up2stream and Piano together ? (without a raspberry Pi) 2: If it is possible how exactly can I wire them together ? 3: About the DSP in the Piano 2.1, I'm planning on using it for the active crossover, by getting a mono signal from both Up2Streams and then splitting the signals into meds and highs, before sending them to the drivers. I hope the Piano's DSP can be programmed to do this. If so, I assume this is done through a raspberry Pi, as I don't think there is another way of connecting it to a computer. Then, would the Piano 2.1 run with an I2s input from the Up2stream with the DSP program after being disconnected from the RPi ? I would really like to know if all of this can work or if i'm forgetting something. Thanks for your help ! ![]() WiFi&Bluetooth 5.0 Multi-room Stereo Receiver Board-Arylic.com – arylic Piano 2.1 DAC |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Linkplay up2stream/generic module i2s dac connection? | JonesySA | Digital Source | 8 | 9th October 2020 07:50 AM |
Up2Stream WiFi multiroom preamp DIY module | amSam | Analog Line Level | 6 | 13th May 2020 02:48 PM |
WTT: Allo digione signature for allo katana dac | sealand1 | Swap Meet | 1 | 1st March 2020 04:43 AM |
Up2stream and Wondom Jab 2 (Wifi & Bluetooth) | IamPar | Class D | 2 | 4th July 2019 10:15 AM |
Allo Allo! | ianpengelly | Introductions | 5 | 30th October 2006 09:31 AM |
New To Site? | Need Help? |
