I have an Arcam black box with the TDA1541A chip. After doing a lot of reading I managed to removed the filter chip and works even better. Then a lot more reading and discovered a lot of people connecting a I2s board to the TDA. I purchased one and struggling to get it to work.
There is a post about removing the muting transistor to enable this which I did but no sound is coming out!
I connected WSBD - LRCK, CLBD to BCLK and DABD to DATA. Connected a 5v power source also to the board but nothing after feeding it with a 16 bit 44.1 signal.
Any help greatly appreciated!
Would that be the transistor (Q209?) that drives the relay that mutes the output at switch on ?There is a post about removing the muting transistor to enable this which I did but no sound is coming out!
Where do you connect the ground from the new CS8412 board? I can't remember where I put it when I used similar in with an old arcam alpha board but I do remember it did matter that there was a ground connection between my 2 boards
Just dragged it out of the cupboard. Looks like I have linked GND from the CS chip to a GND at the TDA - don't think it matters AGND or DGND. However, this might have been necessary for me because I used tube output? It's all too long ago.
Have you got an oscilloscope ? Failing that, have you got something else to which you can connect the CS8412 board to confirm it works ?
My scope is very cheap and limited to Khz not Mhz. My multi meter actually does Mhz!
What am i measuring?
You are the man! Its done!!!! It wouldn't work with the chassis ground but another ground did!
Thank you good sir! Thanks for all that helped!
- Digital Line Level
- TDA1541A and CS8412 how to connect
