Crossover Noise Issue
Old 18th June 2020, 05:15 AM   #1
DQ828 is offline DQ828  Australia
DQ828's Avatar
Default Crossover Noise Issue
I have built the crossover shown in the images below and there is an issue with excessive noise when both boards are connected to the bipolar power supply.
If I unplug the power from either of the boards the noise issue goes away, I'm assuming it is a grounding issues but I'm not sure how to fix it.
I was hoping someone might be able to suggest the best approach.
PS: It amazing how much dust gets thru the vent holes
Old 18th June 2020, 05:29 AM   #2
Mark Whitney is online now Mark Whitney  Netherlands
Mark Whitney's Avatar
Give each board there own transformer, PSU and Ground loop breaker. Did you use a HBR on the inputs?
Regards Mark.
Old 18th June 2020, 06:00 AM   #3
DQ828's Avatar
Mark
Thanks for the input.
I have done 2 other projects similar to this and had no issues with noise. The image below shows a project where is used the Linkwitz crossover boards to drive my speakers and had no noise issues.
There must be a simpler way
PS: Whats a HBR and what input are yuo talking about?
Old 18th June 2020, 08:24 AM   #4
DQ828's Avatar
Default FIXED :)
Well the noise is gone, it's amazing what 1 little green wire can do. I realised after loading up the Linkwitz crossover photo that the board grounds are connected via one of the mounting holes and metal standoffs. The other boards dont have the ground attached to any of the standoff holes so I cobbled something together off the woofer grounds and the noise went away, which I am VERY happy about
  Reply to this post
Crossover Noise IssueHide this!Advertise here!
Event 20/20 BAS V3 noise issue unclepatches Multi-Way 0 16th June 2020 11:50 AM
philips cdm 4/11 noise issue tsudoit Digital Source 2 30th April 2020 07:11 PM
Noise issue on my UcD amp ghitus Class D 6 7th July 2018 10:04 PM
R.F. Noise Issue? OffGridKindaGuy Everything Else 15 30th April 2014 04:18 PM
DCX2496 ch6 noise issue akunec Digital Line Level 5 30th March 2006 10:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
