tcpi (WiFi) interface for sigma studio using a esp8266
I already had some communication with the creator (Rocha, engineer from Brazil) a few months ago.
He will share the files for the esp32 soon. I'm only using the esp32, therefore I didn't do any test so far. But that looks quite promising to avoid the buggy usbi.
I hope he will also share the code to integrate it in own esp32 projects (for example the freedsp aurora).
Hi rocha,
Your module TCPi seems great to avoid using expensive USBi programmer OR buggy chinese FX2LP CY7C68013 based programmers.
About these boards : I wonder if the drivers will still be installable with the very recent W10 octobre release. That release may block non-certified drivers !
I posted a reply on ADI EngineerZone to encourage them fix bugs you discovered in SigmaDSP tcpip mode. Hope this helps !
