DAC AD1862: Almost THT, I2S input, NOS, R-2R
Thread Tools
Old 24th September 2020, 08:47 AM   #891
EUVL is offline EUVL  Europe
Some more transistor combinations.
BC550/560C are somewhat better in H2, at the expense of H3.
KSC1845/KSA992 are much worse.
But these are just numbers.
Does not necessarily tell you about sound.
Patrick
xen-audio.com
Old 24th September 2020, 02:06 PM   #892
diyiggy is offline diyiggy
diyiggy's Avatar
I personnaly use the bc 550/560c in the Pedja arrengment and likes it... I'm not against a little of H3 because the good H2. My ears like it, the power supply and decoupling caps are more changing the sound than H2/H3 level. (ah Pedja's discrete power supply : great).
The 560 from Faitchild are hard to source since it is over and I don't know about the quality of the new smd sibblings ???
The Paradox of the anti-stupidity vaccine : the fools don't want to take it...
Old 24th September 2020, 03:00 PM   #893
Well if you use balanced, then you cancel H2.
So I also look for low H3, assuming my matching can cancel H2 by 10~20dB.
If you do it right (good thermal tracking, etc.) you do not need the output cap as in Pedja's.
Also it is easy enough to add a output follower that adds very little to the distortion.
But of course all a matter of taste.
Both circuits (mine and Pedja's) have poor PSRR. Which is why he uses output cap.
So a stable supply is a must for DC coupling.
I do not use discrete here, because they are not necessarily stable over time.
LT3045/3094 is a better choice here.
Patrick
PS : Of course I (and I am sure also Pedja) know how to do this with good PSRR.
Just adds too much complication.
xen-audio.com
Old 24th September 2020, 05:13 PM   #894
Let's have some more fun with some unobtaniums.
Doesn't cost money in Spice.
Best performance, in simulations.
Patrick
xen-audio.com
Old 24th September 2020, 07:36 PM   #895
diyiggy's Avatar
I like the darlington reg in the emitter follower conf without local feedback at its outputt, it's subjectivly sounding fast to me and let me focus to snake oil caps after the diodes bridge. It's enough for my ears with such pcm chips and low speeds. Indeed it works better for me with C-Core traffos and the RC Pedja is using as filter with the main smoothing cap. It's subjectivly allows according the circuit layout and grounding to work with very low value after the darlington and just decouple load with small values if the ears don't see what you can look at scope... But must say Pedja is doing very good layouts and pcbs, despite looking simple it's certainly not and full of experience... very good designer !
Old 27th September 2020, 08:56 PM   #896
pistollero is offline pistollero  Portugal
pistollero's Avatar
Anyone using 1000pf, and other values instead of 47pf? Or no cap??
What is the relation between the value of the resistor and the cap?
Old 27th September 2020, 10:16 PM   #897
miro1360 is online now miro1360  Europe
@pistollero
try no cap
... 1000pF still be in the limit for any VFA opamp, but can cause an oscillation for a CFA opamp..
the higher the value, the more audibly affected the sound (by a capacitor type)
anyway, read article:
transimpedance amplifier - opamp I/V
Old 27th September 2020, 10:25 PM   #898
diyiggy's Avatar
oups, my bad, I believed it was about the I/V circuitry filtering when I asked 1 nF vs 47 pF ! For the oaps I didn't purchased the cap as well
Old 27th September 2020, 11:19 PM   #899
@diyiggy
1nF could be the maximum, but there will be an audible sound effect caused by this high capacitor value, it is often negative - colored by the diaelectric and similar things
... go with the lowest value as possible, 47p is stable and the sound coloration is low ... and best of all, if the capacitor can be omitted
... did you even try THS3121? (or a near family)
Old 27th September 2020, 11:43 PM   #900
diyiggy's Avatar
yes yes yes, I was not talking about this capacitor, my mistake ! As said i didn't purchase the 47 pF at all for the feedback of the oaps...
No never tried that oap !
The only oap I have in my system is the opa 861, the pre stage is 100% discrete in my pre and the amp...
On the chief menu we have here the 861 again, the opa1612, the opa1656, the ada I advised and the opa 810 ! Let see what happen but because the reg stage it will take 2 months imo before I can edit about the ones I prefer in my whole setup ! many I/V resistor to try as well and half a ton of caps ! That's you have to compete with the Painkiller Ad1862 discrete and the AYA II tda1541A dac the last being still my Ref... so I have to make some great effort to try to optomize while staying in the spirit of the board, KISS but good parts well chosed !
DAC AD1862: Almost THT, I2S input, NOS, R-2RHide this!Advertise here!
Thread Tools
I2S to AD1862 batteryman Digital Line Level 24 30th November 2018 09:01 AM
FS: AD1862 R2R NOS DAC from diyinhk + miro1360 Swap Meet 2 1st November 2018 08:25 PM
AD1862 balanced Dac batteryman Digital Line Level 0 9th September 2018 03:24 PM
?? on using the AD1862 - jitter and LE input B Cullingford Digital Source 9 28th September 2005 07:08 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
