DAC AD1862: Almost THT, I2S input, NOS, R-2R
Old 4th August 2020, 02:34 PM   #661
miro1360 is offline miro1360  Europe
do not bother with output impedance, normally it is defined directly by the opamp, ideally it should be small ... the resistance of R10/R11 can help with capacitive loads, use anything between 50-100R
Old 4th August 2020, 02:34 PM   #662
surfparadise is offline surfparadise  Italy
Thanks!
Old 4th August 2020, 02:53 PM   #663
pistollero is offline pistollero  Portugal
Hello friends, anyone can tell me the max sample rate ad1862 plays or admits??
i am asking because i try to play upsampled files to 768khz and play at low volume, but i ear crackles and distortion when i turn volume higher.
It is strange because i try the same jdlsoundsi2soverusb board with pcm1702 and 1704 and both play 768khz perfect with no cracks or distortion.
Old 4th August 2020, 03:11 PM   #664
have you tried the lower frequency? try 352.8 kHz
352.8 kHz is mentioned in datasheet
Old 4th August 2020, 03:18 PM   #665
i will try when i get home. Its only a test because i usually ear in NOS mode
Old 4th August 2020, 09:40 PM   #666
Anyone know this components reseller?
Electronic Components Distributor | JLCPCB & EasyEDA Parts Online store - LCSC.COM
The prices are really good..
Old 4th August 2020, 10:05 PM   #667
pronk is online now pronk  Canada
I've used both JLCPCB and LCSC for several years. Service and prices have been very good. LCSC's parts inventory is not huge so I still often also use Mouser and Digikey.
Parts selection on LCSC's website can be slow. Many manufacturers are unknown to me and datasheets are often only in Chinese. The cost savings are usually worth the extra effort.
Old 4th August 2020, 10:26 PM   #668
Thanks.
Seems a big reseller, so I think that all the components are original. What do you think about it?
Old 4th August 2020, 10:42 PM   #669
Not sure what you are asking. Nothing I have received from LCSC has been obviously fake or defective. They appear to be a large industrial supplier much like Mouser and Digikey.
Old 5th August 2020, 04:40 AM   #670
happylistening is offline happylistening
Default AD1862 arrived
AD1862 came, will send out to GBers. May you give me your postal address by PM and I will send out ASAP
File Type: jpg 0d24d496-c97a-46e4-919a-a60237849c83.jpg (114.9 KB, 189 views)
DAC AD1862: Almost THT, I2S input, NOS, R-2RHide this!Advertise here!
I2S to AD1862 batteryman Digital Line Level 24 30th November 2018 08:01 AM
FS: AD1862 R2R NOS DAC from diyinhk + miro1360 Swap Meet 2 1st November 2018 07:25 PM
AD1862 balanced Dac batteryman Digital Line Level 0 9th September 2018 02:24 PM
?? on using the AD1862 - jitter and LE input B Cullingford Digital Source 9 28th September 2005 06:08 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
