DAC AD1862: Almost THT, I2S input, NOS, R-2R
Old Yesterday, 04:23 AM   #301
miro1360 is offline miro1360  Europe
Originally Posted by abraxalito View Post
No, haven't done it yet but have been thinking about it for a long time. I started a thread here : Cheap ARM MCUs for RBCD audio
I will check your thread and if I get a good idea, I will contribute
Originally Posted by diyiggy View Post
... As Ebay as we saw ! ...
diyiggy, check the ebay item once again, the seller typed that it is an used item and he clearly showed it on the pictures
Old Yesterday, 01:32 PM   #302
Joseph K is online now Joseph K  Hungary
Originally Posted by laserscrape View Post
Is passive IV + tube buffer (no gain?) your preferred choice for the PCM56?
I have been using purely passive resistor IV (no trafo) with AD1862 and it sounds so good, the SQ trade offs of passive IV with this DAC are very low compared to any other DAC ive used... this explains why the trafo also sounded so good here compared to other applications.
Yes at that time I did not find anything that would work better. I wrongly called it 'buffer', it's a 12B4 with it's gain (a low mu tube, though. & low distortion, high drive and fast.. Very much an opamp, effectively.. .)
Today I would do it with the OPA1656. So much so that I will do a redesign and try..
There is one catch: with the tube stage I have taken advantage of eliminating the built in bias current source in the PCM63(K)..I do remember that was a real step forward.. Previously tried a bunch of bypass options in that position, nothing was comparable to the no bias..
DAC AD1862: Almost THT, I2S input, NOS, R-2RHide this!Advertise here!
I2S to AD1862 batteryman Digital Line Level 24 30th November 2018 08:01 AM
FS: AD1862 R2R NOS DAC from diyinhk + miro1360 Swap Meet 2 1st November 2018 07:25 PM
AD1862 balanced Dac batteryman Digital Line Level 0 9th September 2018 02:24 PM
?? on using the AD1862 - jitter and LE input B Cullingford Digital Source 9 28th September 2005 06:08 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
