PCM1794 vs PCM1793 balanced output?
PCM1794 vs PCM1793 balanced output? Please consider donating to help us continue to serve you.
Old 15th January 2020, 04:47 PM   #11
abza is offline abza  South Africa
Aha, interesting - I wasn't aware this could be achieved passively. That's pretty appealing, if anything just for the lower component count! So a simple resistor to ground is all that's needed to convert current to voltage?
Here's what I have as a quick mockup of that, including your idea to fold the shunt resistor into acting as some low pass filtering:
C1: DC blocking cap, and part of the high pass filter together with R1.
R1: I/V resistor. Is this layout correct?
C2: Initial LP filtering
R2: Low pass filter with C3, as well as gain control with RFB.
Old 15th January 2020, 08:04 PM   #12
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
The C1 blocking cap. MUST be located somewhere AFTER the I/V resistor R1. This is because the PCM1794A needs to pass a 6.2mA D.C. bias current from each output pin to ground, which it does here via R1. As shown, C1 would block passage of this necessary current. I would locate C1 as suggested earlier, between the 2nd filter pole and the output amplifier. I suggest this so that the C1 doesn't have to pass the full-band DAC output signal. Also, R2, C3 values should be chosen with the values of R1, C2 in mind, so that the in-band response remains flat to 20kHz.
PCM1794 vs PCM1793 balanced output?Hide this!Advertise here!
DDDAC PCM1794 Output Coupling carlsor Digital Line Level 8 27th April 2015 10:14 PM
Need help with tubed output for PCM1793 DAC kkillebrew Tubes / Valves 17 30th May 2011 04:36 AM
PCM1794 output stage meta Digital Source 15 8th July 2004 03:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
