Bad PCM1702 or AD823?
Old 10th October 2019, 02:40 AM   #1
astouffer is offline astouffer  United States
astouffer's Avatar
Default Bad PCM1702 or AD823?
I'm working on somewhat of a strange high end DAC with a problem. Each channel has two PCM1702s that feed into an AD823 for the I/V conversion. One output from the AD823 looks great with a sinewave playing and one side looks terrible.
How can I tell if the PCM1702 is bad or the AD823? With no signals coming into the AD823 each output is nearly at 0v (5mv offset). Anyhow here is what the two AD823 outputs look like.
Old 10th October 2019, 02:48 AM   #2
rayma is offline rayma  United States
The odds are it's the PCM1702. Everything is soldered in?
Old 10th October 2019, 03:26 AM   #3
astouffer's Avatar
rayma, thank you for the quick reply. Yes everything is soldered in. My suspicion was leaning towards the PCM1702 as well. The components and build quality are great but the pcb itself is fragile. On a previous repair I cut all the pins from the chip and removed them separately.
Old 10th October 2019, 03:33 AM   #4
Then that's what I'd do, but use a moderately dull cutter to reduce stress on the board.
Good luck. No plated through holes?
Bad PCM1702 or AD823?Hide this!Advertise here!
ES9018K2M + SA9023 + dual AD823 USB interface - help me mod it Expansion2 Digital Line Level 10 29th September 2016 01:18 PM
AD823 openback Chip Amps 7 27th January 2012 06:02 AM
My PCM17024 DAC parhelia Digital Line Level 4 22nd August 2011 05:22 AM
where can I get some AD823 op amp? ttan98 Chip Amps 4 30th April 2009 01:44 AM
AD823 Lo pass filter schematic jmar Digital Source 7 2nd February 2006 04:18 PM
Copyright ©1999-2019 diyAudio
