how to connect transformer on DAC output
Old 6th October 2019, 07:54 PM   #1
Albrerta is offline Albrerta  Canada
Default how to connect transformer on DAC output
I want to mod my dual AK4495 DAC with output transformers, by looking at the board I can see that the DAC chips parallel the output so each handle one channel. but it happens after a resistor, see pic below
Now I wonder where the connection of output transformer goes, should before those resistors, or after
Old 7th October 2019, 02:22 AM   #2
synonymous is offline synonymous  United States
Send a message via MSN to synonymous
The resistors are most likely for creating a LP filter at the DAC output..
Transformers themselves are a LP filter and in most cases do not need the LP filter before them.
It shouldn't make a difference if you put the transformers before or after, although I can say that my new project will not have the resistors in the circuit. Try your luck.
Make sure that you ground the transformer cases.
Transformers took my project from cute to professional, got rid of the most minute artifacts.
Good luck
S
Old 7th October 2019, 03:34 AM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Since your DAC is a dual AK4495 this most likely means one chip is devoted to L channel and the other to R channel, meaning they're running mono. Therefore probably the resistors are there to parallel the outputs. You haven't said anything about your transformer - if it has two primaries then you may well be able to connect each primary to an output directly and dispense with the resistors. But then again, resistors have the function of ensuring the output opamps don't go unstable with capacitive loads so you might still need them even with the transformer - the trafo primary should go to the summing junction of the resistors (that's after the resistors).
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 7th October 2019, 03:57 AM   #4
Originally Posted by abraxalito View Post
....But then again, resistors have the function of ensuring the output opamps don't go unstable with capacitive loads so you might still need them even with the transformer - the trafo primary should go to the summing junction of the resistors (that's after the resistors).
That's what I thought about, the resistors may have stability purpose because essentially dac chip 2 channels output need to connect together
how to connect transformer on DAC outputHide this!Advertise here!
How to connect a Denon AU-320 step-up MC transformer 355F1 Analogue Source 10 28th June 2019 02:11 AM
how to connect output transformers?? adledlad Tubes / Valves 5 12th September 2015 05:58 PM
Two Transformer connect ground together steven2583 Power Supplies 3 24th May 2013 07:44 AM
How to connect a toroidal transformer giralfino Power Supplies 16 10th December 2010 11:33 AM
How to connect 62 ohm headphone to 8 ohm output Sunsun22 Headphone Systems 15 16th June 2007 01:29 PM
Copyright ©1999-2019 diyAudio
